Is Newton's 3rd law incorrect?
  • Context: High School
  • Thread starter Thread starter pradipta
    Law Newton 3rd law
The discussion revolves around the validity and applicability of Newton's third law of motion, particularly in the context of both macroscopic and microscopic bodies. Participants explore various interpretations, implications, and scenarios related to the law, including its instantaneous nature and its relationship with energy transfer and interactions at different scales.
  • Some participants assert that Newton's third law is not incorrect and applies to both macroscopic and microscopic bodies, while others question its instantaneous nature.
  • A few participants argue that the law is applicable in scenarios involving chemical reactions, though this is contested by others who state that such reactions do not pertain to Newton's third law.
  • There are claims that the interaction between forces is not instantaneous due to the speed of light being the limiting speed of interactions, while others suggest that local interactions can be instantaneous.
  • One participant presents a scenario involving charged particles and Lorentz forces to question whether the forces are equal and opposite at a specific moment.
  • Some participants discuss energy transfer and losses when forces are applied, suggesting that the forces may not always be equal due to energy dissipation.
  • The concept of virtual photons and their role in interactions is debated, with some participants expressing skepticism about their physical reality.
  • There are discussions regarding the mathematical nature of Newton's third law and its implications for conservation of momentum.
Participants do not reach a consensus on the applicability and interpretation of Newton's third law. Multiple competing views remain, particularly regarding its instantaneous nature and the implications of energy transfer.
Participants express uncertainty regarding the definitions of forces and interactions, and there are unresolved mathematical considerations related to the scenarios discussed. The discussion also highlights the complexity of applying classical mechanics to quantum scenarios.
pradipta
is the concept hypthetical
No it's not incorrect...It is applicable for macroscopic bodies but not applicable for microscopic bodies.
To every actions there's equal and opposite reaction is not hypothetical.
It is true for microscopic and macroscopic bodies as the sizes of forces acting on bodies are acting equally.
But we can't say that the reaction is instantaneous as when a chemical reaction takes place the reaction doesn't take place in seconds it does take time.
Chemical reactions are not what is being referred to in Newton's third law.
No. But why are you thinking it might be?
Newton's third law work for every object microscopic as well as macroscopic. And it is instantaneous just think about the fact that when someone shoots a bullet from the rifle or any gun the recoils occur at that moment only and it occurs in the opposite direction of bullet fired
It can't be instantaneous in the sense that c is the limiting speed of interactions.
lightarrow
lightarrow
Albert Einstein proved through mathematical equations that the carriers which carry the information of gravity calles gravitons work at the speed of light so gravity works as fast as light
So what is your point? What does the transfer of the reaction from one part of the gun to another or to your shoulder have to do with Newton's third law?
Both forces can still be the same and in opposite directions at the same time, because both forces will be delayed by the same amount.
Consider two equal positive charges q1 and q2. q1 is traveling along the x-axis in the +x direction, and and q2 is at rest on the +y-axis, a distance y away from the origin. Calculate the Lorentz forces ##\vec F_1 = q_1 (\vec E_2 + \vec v_1 \times \vec B_2)## and ##\vec F_2 = q_2 (\vec E_1 + \vec v_2 \times \vec B_1)## at the moment that q1 passes through the origin. Are those two forces equal in magnitude and opposite in direction?
if i give a 10 Newton force to an object say a steel scrap then the force will transfer automatically to sound energy,heat energy etcetc and during this time there will be a loss in energy which in return may give 9.5 or 9.8 or so but it can't give exact or equal to 10 Newton...
It can if the interaction is locally only. Of course this requires a much more general concept of "body".
Can you expand a bit?
lightarrow
This description is flawed. You don't "give" a force and then receive another one back.
The force is a measure of interaction between two objects. If there is an interaction between you and another object, you and the object simultaneously act with a force of 10N on each other. If there are other forces acting at the same time, they are part of other 3rd law pairs. They can decrease the energy of the system, maybe.
The interaction between two distant charged particles can't be instantaneous but the local interaction between the particles and their electromagnetic field is instantaneous. Newton's third law applies to this situation if photons or even virtual photons are considered to be "bodies".
This is not related to Newton's 3rd law. Newton's third law says that the force you exert on the steel scrap is the same as the force that the steel scrap exerts back on you.
To amplify even a bit more: you don't "give" a force and then receive another one back because that implies that they are separate events. They aren't. The application of/exchange of forces is a single event.
It seems very very "stretched" to me, considered that many physicists consider virtual photons as nothing else than a mathematical "trick".
lightarrow
I don't think that graviton is a proved particle yet.is it?
Next time, when you make a thread asking for something like this, please also include THIS as your "supporting argument" in that very first post. Otherwise, your question just hangs there without any kind of justification or impetus on why you would ask such a thing (did it come to you in a dream?).
Furthermore, as nasu has replied, we can also correct the mistake in your understanding on why you would think of such a thing based on this example. It is a more CONCRETE and clearer way to address such a mistake, rather than some hand-waving description on why your understanding is faulty.
As a reminder, please note that the PF Rules require that you present a clear and as complete of a post as possible when presenting a question such as this.
Zz.
Isn't the third law a mathematical "trick" too? There is no reason why forces must cancel each other pairwise out. Conservation of momentum just requires that the sum of all forces is zero in inertial systems. For example, if there are three bodies A, B and C this would allow that
A exerts a force FAB to B but no force to C
B exerts a force FBC to C but no force to A
C exerts a force FCA to A but no force to B
with
FAB + FBC + FCA = 0
The third law does not allow such ternary interactions and requires to describe the same situation with three binary interactions. Due to the superposition principle this is always possible but it is impossible to distinguish the two cases experimentally. We are using the binary interactions because they appear to be useful. But we cannot show that they really exist in systems with more than two interacting bodies. In this sense they are just a mathematical "trick". But there is nothing wrong with it.
other forces means?specfy
I don't know, those ones you had in mind when you described dissipation of mechanical energy.
And what does conservation of angular momentum requires?
lightarrow
That requires that the sum of all torques is zero but that's another topic.
Why it's "another topic"? We are discussing "Newton's 3d law", not "first law of statics".
lightarrow
lightarrow said:
Why it's "another topic"?.
Because we are discussion Newton's 3rd law and not conservation of angular momentum.
And why do you think that conservation of angular momentum is not related to Newton's 3d law?
Edit. I explain.
For a system of mass points, the fact the resultant moment of internal forces is zero comes from Newton's 3d law. Conservation of the system's angular momentum can be proved using this fact.
lightarrow
  • · Replies 24 ·
  • · Replies 62 ·
  • · Replies 22 ·
  • · Replies 31 ·
  • · Replies 19 ·
