I Is Relativistic Action for a beam of light = zero?
LarryS
TL;DR Summary
Under the RELATIVISTIC definition of Action, is the Action for a free photon always zero?
Under the RELATIVISTIC definition of Action, is the Action for a beam of light always zero?
Thanks in advance.
What do you think the "RELATIVISTIC definition of Action" (not sure why you felt it necessary to shout) is? Have you tried looking in any textbooks or other references?
Let's take a step back. Sans shouting. What makes you think the numeric value of the action has any meaning whatsoever?
The Lagrangian Density for the EM field can be derived from Maxwell's Equations (via the EM Field Tensor). Also, from Maxwell's Equations, the electric and magnetic energy densities of an EM plane wave are equal. So, if you focus only on the EM plane wave, the Lagrangian Density for that would be identically zero. Or, am I not seeing something?
How would the equations of motion change if you added a constant to the Lagrangian?
When you answer "not at all", the next question is "then how can the numeric value matter?"
Actually, it's the other way around: Maxwell's Equations are the Euler-Lagrange equations for the EM field Lagrangian.
More precisely, a source-free EM plane wave.
Unless, as @Vanadium 50 says, you add an arbitrary constant, which has no effect on the equations of motion.
However, if we leave that aside, what, exactly, remains unanswered from your original question? Do you realize that Maxwell's Equations, and the Lagrangian they are derived from, are relativistic? That is, they are Lorentz invariant?
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
