C/C++ Is std::bind Reentrant? A Brief Overview of Reentrancy in C++ Functions
  • Thread starter Thread starter ORF
The discussion centers on the reentrancy of std::bind in C++. The initial inquiry questions whether std::bind is reentrant, with concerns about how bound values are stored and retrieved. It is clarified that std::bind does store bound values in the object it returns, but retrieving these values is not straightforward. The conversation reveals that reentrancy refers to the ability to call std::bind again while it is executing, particularly in multi-threaded contexts. It is noted that std::bind does not call itself, which supports its reentrant nature. The discussion also touches on the implementation specifics in Visual C++ 2017, mentioning that optimization can render std::bind calls effectively non-existent in terms of stack usage. Finally, the importance of understanding reentrancy in relation to global variables and non-reentrant functions is highlighted, suggesting further research for clarity.
ORF
Technology news on Phys.org
I believe all information is stored in the object that std::bind returns
Hello,
I am a kind of noob... how can you retrieve the bound arguments from the returned object?
http://www.cplusplus.com/reference/functional/bind/
Thank you for your time.
Regards,
ORF
Can we go back a bit? What are you trying to accomplish? Are you using recursion?
I do know there was some debate about whether or not std::bind can be called recursively. You can do it, of course, but the consequences were not clear a couple of years back. I remember a github entry for std::bind on the subject.
Likes QuantumQuest
Hello,
No, I'm not using recursion.
I was told that std::bind is not reentrant because the bound (copied) arguments may not be retrievable.
I didn't find any information about how to retrieve the bound arguments, and that is my question: is std::bind reentrant? (or, can you retrieve the bound arguments somehow?)
Regards,
ORF
Some of the stuff isn't stored at all. The implementation of this isn't a part of the standard BTW, this is for visual c++ 2017.
Room is reserved on the stack for 8 bytes for a function pointer and 8 bytes for each argument. Only the arguments that are given a value are stored here. The compiler seems to know the rest. Note that it isn't allowed to change the order of the paramaters, or which ones are bound to a value
C:
auto f1 = std::bind(myfunc, _1, _2, 3)
f1 = std::bind(myfunc, _2, _1, 3)   //ERROR
f1 = std::bind(myfunc, _1, 2, 3)   //ERROR
f1 = std::bind(myfunc, _1, _2, 4)  //Only this is ok.
mentor add code tags
If I turn on optimization, the entire std::bind call is optimized to nothing. It still reserves room for f1 on the stack, but it isn't used ever.
That should be pretty reentrant.
Likes QuantumQuest
Hello,
but, if once it is initialized, you can not know the bound arguments... that is also reentrant? (probably I have a misconception of what reentrancy is)
Thank you very much for your time.
Regards,
ORF
Reentrant is if it is OK to call std::bind again while it is still executting. This could happen in a multi-threaded program or if std::bind somehow calls itself.
The first one should be ok because each of the calls only works on its local data on the stack. std::bind calling itself shouldn't happen because std::bind doesn't call anything. Even if you try to pass std::bind to itself, it won't call itself.
Likes QuantumQuest and ORF
Hello,
Thank you very much, that was the answer I needed! :D
Cheers!
ORF
In addition to what willem2 said in post #8 in order to decide for a function if it is reentrant or not you can test it and analyze its behavior, regarding global variables (if they are used) , call of non-reentrant functions and self code modification. You can google these things in order to see and learn the details and / or post here for further help. Also, C++ documentation leaves many things to implementation(s). Besides the links you gave in previous posts it might be of help to take also a look here.
