Is the Cloud of Hydrogen Gas Likely to Collapse?
  • Thread starter Thread starter Meganwright
    Cloud Collapse
Meganwright
A cloud consists of 8 solar masses of hydrogen gas (H2). Its temperature is 20 K and its radius is 0.6 light years. Will it collapse?
jeans mass
3. The Attempt at a Solution [/b
I've tried to use jeans mass to solve this however I am finding the formula difficult to understand
Show your work.
So far I'm using the formula
3/2kT <GMm/R
And (3KT/2Gm) x k >mj
I'm substituting m=2.167x10^-27
G=6.67x10^-11
K=1.38x10^-23
T=20
R=0.6
However I'm not sure what it is exactly that I'm gaining from using these formulae?
I'm getting that (3kT/2Gm) x R = 1.115011357 x 10^15 ?
I'm aiming to get an answer of
Jeans mass = 1.05 x 10^31 kg
Which is less than 8 solar masses (1.6 x 10 ^31) so it will collapse?
I struggled to follow your logic above. Seem to be a few typos:
(3KT/2Gm) x k >mj
(3kT/2Gm) x R = Mj ?
√((3kT/2Gm) x R) = 1.115011357 x 10^15 ?
Also, I don't see online a formula with that 3/2 factor. I see one with 15/4pi, another that approximates that to 1. Anyway, using your 3/2 I get that the Jeans length/radius = 0.84, which suggests to me it won't collapse. (I'm a bit confused over whether the Jeans length is a radius or a diameter, but if it's a diameter then the actual radius is much too large to collapse.)
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
