torquil said:
At very large energy, the smallness of the renormalized coupling constant, due to asymptotic freedom, makes the single free gluons appropriate as a in- and out-states in perturbative calculations. By this statement I do not mean that they qualify as "physical states", but only that the perturbation theory is well-defined in this case (at the level of rigour required by physicists).
Correct.
torquil said:
I guess by a "physical state" one means a state that is a) on-shell and not negative-norm, and b) gauge-invariant, at least up to a constant complex phase factor?
If you use a physical gauge (i.e. A°=0 + Coulomb gauge condition) you never deal with negative norm states. And yes, physical states are gauge invariant.
The Gauß law annihilates physical states
G^a(x)|\text{phys}\rangle=0
In addition it acts as the local generator of time-independent small gauge transformations leaving A°=0 invariant:
U[\theta] = e^{-i\int d^3x\,\theta^a(x)\,G^a(x)}
A gauge trf. is then generated by
\mathcal{O} \to \mathcal{O}^\prime = U[\theta] \mathcal{O} U^\dagger[\theta]
which can be applied tofermionic operators and to gauge field operators like A
a and E
a.
b/c the Gauss law annihilates physical states one sees immediateky that for each physical state we have
U[\theta] |\text{phys}\rangle = \text{id}|\text{phys}\rangle
torquil said:
Doesn't your use of Gauss' law only imply that the total charge of the system is conserved in time?
Yes, The Gauß law commutes with H (where both H and G are defined in the kinematical Hilbert space as in the physical one G ~ 0), i.e.
[H,G^a(x)] = 0
(strongly as a Heisenberg equationof motion, not only when acting on physical states).
This is a much stronger condition than charge conservation b/c it holds locally!
torquil said:
For example, if the in-states at t=-infinity had a non-zero total colour charge, ...
This calculation does not makes sense in the physical Hilbert space; it can be done in the kinematical Hilbert space before implementing the Gauß constraint, but there is no good reason to do that.
torquil said:
I mean, the charge is not located on any surface?
By surface charge I mean the following:
\nabla E - \rho = 0
No using integration and Gauß's theorem on gets
\oint E - Q = 0
Therefore one cannot argue that Q=0 unless one imposes "physical conditions" on E or assumes that space is compact. But usually we do not believe that there is something living on the boundary of the universe spoiling this argument ;-)
torquil said:
How would you argument go for a scattering process in QED with two incoming free electrons at T=-infinity?
In QED due to missing confinement one could be interested in this process even if it violates charge neutrality. If you want to do this calculation you must deal with unphysical states. If you want to restrict to physical states the calculation is meaningless.
torquil said:
Would you know a good reference for these matters...? After wading through Peskin-Schröder, Weinberg & Kaku just now I didn't find a clear explanation. I guess I could have been more thorough, though.
Quantum Mechanics of Gauge Fixing
Annals of Physics
Vol. 233, No. 1 (1994), p. 17-50
QCD in the Axial Gauge Representation
Annals of Physics
Vol. 233, No. 2 (1994), p. 317-373
