milesyoung
- 818
- 67
Let's just start with this:
Acceleration happens in the direction of the net force on the point charge. Any motion the particle has is in the direction of its velocity. Just consider where the particle is at some time [itex]t[/itex] and at some time [itex]t + \delta t[/itex] later. If you keep reducing [itex]\delta t[/itex] then it should be clear that the direction of its displacement vector will tend to the direction of its velocity.
Don't take my word for it. Do some simple math:
The work done on the point charge by the magnetic force between some time [itex]t_1[/itex] and [itex]t_2[/itex] is given by:
[tex] W = \int_{t_1}^{t_2} \mathbf{F_\mathbf{mag}} \cdot \mathbf{v} \, \mathrm{d}t = \int_{t_1}^{t_2} \left( q \mathbf{v} \times \mathbf{B} \right) \cdot \mathbf{v} \, \mathrm{d}t = \int_{t_1}^{t_2} 0 \, \mathrm{d}t = 0[/tex]
pleco said:F= qv X B clearly says magnetic force lines are perpendicular to magnetic field lines. F= ma clearly says acceleration, and consequently displacement, can only be in the direction of the force. Where do you see a problem?
