Diagonalizability of Singular Matrices: Investigating Rank and Eigenvectors
  • Thread starter Dank2
  • Tags
    Matrix
In summary, the Attempt at a Solution states that A is diagonalizable if and only if there is a matrix S such that:p(A+5I) < p(A)p - is the rank of the matrixI - is the identity matrix, andS(A+5I)S^{-1} = SAS^{-1} + 5I = diag(α+5,β+5,γ+5)
  • #36
fresh_42 said:
So, the second isn't applicable. How many eigenvectors of ##A## arise from the dimension of the nullspace of ##A+5I##?
And how many from the nullspace of ##A## itself? Are all of these linearly independent? And why?
The former considerations showed us which eigenvalues there have to be and which possibilities exist. They are not really necessary but were easy to do.
I understand it if we assume A is the matrix that has it's eigenvalues on the diagonal. But what if A other matrix? in your question you assume A = diag(-5,-5,0) ?
  • #37
No, I only assume the equation ##3 = dim V = p(A+5I) + \dim \ker(A+5I) = 1 + 2##.
That gives me two linear independent vectors ##x,y## in the nullspace of ##A+5I##. Both have to be eigenvectors of ##A## as well, namely to the eigenvalue ##-5##.
Another vector ##z## spans the nullspace of ##A## by the same equation for ##A## instead.
It only remains to show that all three are linear independent.
So assume ##0 = ax+by+cz##. Why are all coefficients ##a,b,c## equal to zero?
Likes Dank2
  • #38
fresh_42 said:
Both have to be eigenvectors of AAA as well
why ?
  • #39
Dank2 said:
why ?
Come on! ##(A+5I)x = 0 = Ax +5x ⇔ Ax = -5x##
Edit: You got to reset yourself. :wink:
Likes Dank2
  • #40
fresh_42 said:
So assume 0=ax+by+cz0=ax+by+cz0 = ax+by+cz. Why are all coefficients a,b,ca,b,ca,b,c equal to zero?
Well you've just shown that the algebraic multiplicity is equal to the geometric multiplicity, so it's done. then A is diagonalizable, and the eigenvectors are linearly independent. therefore a=b=c=0
  • #41
Just so i would know where i stand, how hard would you rate this question from 1-10
  • #42
I'm just bad at math, with very poor backround
  • #43
Knowing the solution: easy. It actually contained two parts: ruling out other combinations of ranks and then investigate the various eigenvectors and -values.
However, as you could have seen by my comments I started to think way too complicated by myself.
This is a usual phenomena. As long as you don't know something, it appears hard, whereas it turns out to be easy if you know how to do it - often, but not always. Unfortunately there are theorems that will stay hard, even if one knows how to prove them. But this doesn't matter: you learned something about the Jordan normal form, the algebraic and geometric multiplicity and so on. So even longer ways to a solution can be no lost effort.
Likes Dank2
