B Is the probability of a quantum outcome ever zero such as with....
CosmicVoyager
TL;DR Summary
Is the probability of a quantum outcome ever zero such as with the location of an electron around atom or with radioactive decay?
Greetings,
Given an infinite universe or an infinite number of universes?
- Regarding the location of an electron around an atom, is there a tiny volume in which finding the electron 100%? Or is there a possibility, no matter how remote, it might be found a meter away or a kilometer away?
- Regarding radioactive decay, must the half-life rule always occur? Is there any possibility that all the radioactive atoms in a billion atom sample will decay at once?
Are such outcomes prevented by matter, energy, space, and time being quantized? By Planck units? Does that cause probabilities to become zero?
Thanks
There are zero or one probabilities in quantum mechanics.
For example there are transitions in atoms (best example is hydrogen) which can't occur. So called forbidden transitions.
Also electrons are fermions and thus can't occupy the same quantum numbers. I.e. if you have a wave function ##\psi(x_1, x_2)## this will become zero for ##x_1 \to x_2##. And if the wavefunction is zero then the probability (density) ##|\psi(x, x)|^2## is also zero.
Regarding your second question: This is effectively a statistical property. So in theory.. yes. However I reckon the probability of a billion atoms all decaying at the same time is effectively zero. So in theory yes, in practice not really.
Likes CosmicVoyager, vanhees71 and PeroK
Basic QM is non relativistic and there is a non-zero probability of a particle being found outside its future light cone. That's one reason that ultimately you need QFT to describe elementary particles.
Moreover, in order to test something you need a realistic probability in order to confirm the theory with experiment. If the probability of something is vanishingly small, then it's experimentally indistinguishable from the impossible.
Likes CosmicVoyager and DrChinese
Thanks for your very helpful replies. So, though the odds of us observing such events is practically zero, in an infinite universe or in an infinite number of universes, these events would occur. And would actually occur an infinite number of times, correct?
I'm not sure that's a well-defined question. In QM generally you can only talk about the measurements you do make.
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
