Is the Universe Expanding Due to Spinning?
The discussion revolves around the hypothesis that the universe may be spinning and whether this could provide an explanation for the phenomenon of dark energy. Participants explore the implications of a spinning universe, including potential outward forces and the nature of cosmological expansion. The conversation includes theoretical considerations, challenges to the idea, and references to existing literature.
  • Christopher R. proposes that if the universe is spinning, it could create an outward pull that might address the dark energy problem, citing a rotational inertia calculation.
  • Some participants question the reasoning behind the idea of an outward pull resulting from a spinning universe.
  • Concerns are raised about the concept of a spinning universe, particularly regarding the absence of a center around which it would spin.
  • One participant mentions that current observations are consistent with zero rotational velocity, suggesting that rotation cannot play a significant role in cosmological expansion.
  • Another participant discusses the Gödel metric, noting that while it allows for rotation in a theoretical context, it does not align with observed cosmological behavior.
  • There is acknowledgment of a mathematical solution that allows for rotation without a center, but its relevance to the actual universe remains debated.
  • Some participants express a belief in the possibility of galaxies spinning around a common center, though this view is challenged by others referencing previous discussions.
Participants express a range of views on the spinning universe hypothesis, with some challenging its validity and others exploring its implications. There is no consensus on the topic, and the discussion remains unresolved.
Limitations include the reliance on theoretical models that may not reflect the actual conditions of the universe, as well as the absence of observational evidence supporting significant rotation.
R0dr1go
TL;DR
Is the universe spinning? Plus rotational inertia calculations.
Hello all,
I recently did a thought experiment and thought, "what if the universe as a whole is spinning?" This could solve the dark energy problem, as if the universe was spinning, there would be outward pull, and therefore keep the universe expanding. And, I don't know if this means anything, but I did a rotational inertia calculation for the visible universe and came up with the number 6.99*10^63, and the percentage of dark energy in the universe is 69%. This could mean absolutely nothing, as they are two different numbers, but I found that kind of interesting. Any thoughts? Thanks,
Christopher R.
  • Skeptical
Astronomy news on Phys.org
Why would there be an outward pull?
And just where do you think the center is that it is spinning about?
Your question is asked here several times a year. I suggest a forum search to gain understanding of why it makes no sense.
I found this old thread where you essentially posted the same thing and were told you were wrong. :)
https://www.physicsforums.com/threads/a-spinning-universe.72186/post-3238600
  • Skeptical
Thanks for the link, Vela. I can't remember ever reading about the possibility of rotation being intrinsic in GR before.
@R0dr1go from the other thread:
Because all of the present observation are consistent with zero rotational velocity, it is not possible to attribute any prominent cosmological role to rotation. In particular, centrifugal forces cannot contribute significantly to cosmological expansion.
Naively, I would say that "rotating universe" doesn't make any sense unless you embed 4-dimensional universe into higher-dimensional "ambient" spacetime. But that seems to be wrong as I further read about the Goedel metric mentioned in the thread linked by @vela in post #4. The metric looks like a solution to Einstein's equation in regular 4D spacetime.
Anyway, the observations suggest that we are not living in a rotating universe. Few statements from wiki:
Besides rotating, this model exhibits no Hubble expansion, so it is not a realistic model of the universe in which we live, but can be taken as illustrating an alternative universe
Less well known solutions of Gödel's exhibit both rotation and Hubble expansion and have other qualities of his first model, but traveling into the past is not possible. According to S. W. Hawking, these models could well be a reasonable description of the universe that we observe, however observational data are compatible only with a very low rate of rotation.
Ah yes. You are correct. Thanks. I forgot that there IS a math solution that shows rotation with no center. I see @Drakkith has already quoted what I think is the most pertinent observation in that thread (aside from the fact that there can be a solution without a center)
Thanks for the feedback! I now see the errors in my question, and why it couldn't be possible. Although this particular thought wasn't the answer to the universe, every question lies an answer, whether as noticeable as the sun or as hidden as quarks. Thanks again!
I mean if you think about it every galaxy would have to be spinning around the same thing for us not to hit each other so as it is a possibility I don't think well ever know I know it's short but that's what I believe.
AndrewWayneHarville said:
I mean if you think about it every galaxy would have to be spinning around the same thing for us not to hit each other...
I take it you did not read post #7
  • · Replies 33 ·
10K
  • · Replies 19 ·
