Is the Work Done by a Variable Force Non-Conservative?
59 replies · 6K views · last reply
That's worrying. If you do try that be careful not to use θ for both purposes. Either take the polar coordinates to be (r,φ) or change the given parameter from θ to t, say. I say it is worrying because it makes me wonder whether your teacher has blundered.
MatinSAR said:
Thank you but what do you mean by this ?! I didn't understand.
This one should be Theta ...
No, neither of them matches the given theta. The one you circled would give ##x=r\cos(\theta), y=r\sin(\theta), y/x=\tan(\theta)##. But you are given ##y/x= \frac 12\cot(\theta)##.
If you draw a line from the origin to a point half way along the horizontal dashed blue line, the angle between that and the y-axis is the given theta.
Chestermiller said:
If you are going from A to C, the limits of integration are from ##\theta=0## to ##\theta = \frac{\pi}{2}##. From the equations for F and dr that I gave in post #16, what is the equation for F dotted with dr?
Is it true ?!
Handwritten-style equation: 6a^4 (sinθ cosθ)^2 dθ, a mathematical expression involving the variable θ and constant a.
kuruman said:
Forget ##\theta## as a variable. Try this. You have $$x=2a\sin\theta~;~~2y=2a\cos\theta.$$It follows that $$x^2+4y^2=4a^2 \implies xdx+4ydy=0 \implies dx=-\frac{4y}{x}dy$$ Now $$\mathbf{F}\cdot d\mathbf{r}=(x^2y~\mathbf{\hat x}+xy^2~\mathbf{\hat y})\cdot(dx~\mathbf{\hat x}+dy~\mathbf{\hat y})
=x^2ydx+xy^2dy.$$ Substitute the expression for ##dx## and integrate over ##y##.
Can I send a picture of my work ?! The final answer is unusual ...
Thanks ...
Is it true ?!
Diagram of a quarter-circle arc in the xy-plane from A(0,a) to C(2a,0), with corner B(2a,a) and position vector r from the origin, displacement dr tangent to the arc, and the angle theta marked.
LaTeX is preferable, but if your work is too involved, you can post a picture as long as it is clearly legible and right side up. Use the "Attach files" link, lower left.
Thank you ... I have done it with a math editor.
  • Handwritten-style typeset derivation of work done by a force, with x = 2a sinθ, x² + 4y² = 4a², x dx + 4y dy = 0 giving dx = (−4y/x) dy, and W as a line integral reducing to −3xy² dy and then to xa³ over the limits a to 0 and 0 to a.
haruspex said:
I don't get the factor as 6. Did you handle the signs correctly? The rest looks fine.
What about Theta ?! Did I specify theta correctly?
I get the factor 6 again ! Let me send a picture ...
  • Typeset derivation of a dot product: F = 4a^3 sin^2θ cosθ i + 2a^3 sinθ cos^2θ j, dr = 2a cosθ dθ i − a sinθ dθ j, then F·dr = 6a^4 sin^2θ cos^2θ dθ.
I'm getting what you are getting.
$$ \int 3 x y^2 dy = \int 3 \cdot y^2 \cdot 2 \sqrt{a^2 - y^2} dy $$
Let:
##\frac{y}{a} = \sin \beta##
## \frac{ \sqrt{a^2 - y^2} }{a} = \cos \beta##
It follows that
$$ y^2 = a^2 \sin^2 \beta$$
$$\sqrt{a^2 - y^2} = a \cos \beta$$
$$ dy = a \cos \beta d \beta$$
$$ \implies \int 3 x y^2 dy = 6 a^4 \int \sin^2 \beta \cos^2 \beta d \beta $$
I also get a factor of 6, although I would never have done the math the way that he did it>
Was it true ?!
What was wrong with the way I have done the math :rolleyes:
Can you please tell me what is your final answer ?!
MatinSAR said:
Was it true ?!
I didn't do the integral!
Post your work, it will get checked by someone...
Yes, my mistake… I should have waited until I had the time to check properly.
MatinSAR said:
It is a line integral, not a double integral, so you must arrange that there is only one variable in the integrand. If you want to do it as an integral wrt y then you must first replace all the occurrences of x with what x is as a function of y.
But really, the parametric approach using theta is much easier.
So my answer is wrong , isn't it ?!
Thank you ... I will try to do it using parametric approach and I will send a picture of the work ...
erobz said:
Show the work. Explain how you get the last result?
Thank you ... I will try to do it using parametrich approach and I will send a picture of the work ...
I'm confused. Isn’t that what you already did in post #32? Except that you did not perform the integral.
The integration is very simple. It just involves the use of trigonometric identities.$$(\sin{\theta}\cos{\theta})^2=\frac{\sin^2{2\theta}}{4}=\frac{1-\cos{4\theta}}{8}$$
MatinSAR said:
Hi @MatinSAR. Can I point out a fundamental mistake you are making? I don’t think anyone has mentioned it yet (apologies if they already have).
The final expression for W can not contain x or y (or θ). These are variables which change as you move along the path. They must disappear when the definite integral is evaluated.
You made the same mistake in your Post #1 solution, where your final expression for W contained x and y.
The expression for W can contains only given constants (here only the 'a') and pure numbers like 5, π and √2 (just picking random values as examples).
For example, if you determine the formula for the circumference of a circle, x²+y²=a², it wouldn’t make sense to have x and/or y in the final formula.
Yes. It was unfinished.
Thank you.
Thank you ... I didn't know about this.
I hope it's finally true ...
Handwritten derivation of work done by a force F = 4a^3 sin^2θ cosθ dθ i + 2a^3 sinθ cos^2θ dθ j along a path, ending with W = 3πa^4/8.
The force is conserative so If I choose another path the final answer shouldn't change, Is it true ?!
Is it? What do you get if you integrate from 0 to 2π?
I agree with your answer.
haruspex said:
Is it?
It was mentioned in question.
Thank you.
haruspex said:
Steve4Physics said:
Chestermiller said:
erobz said:
kuruman said:
Mister T said:
I hope I haven't forgotten anyone.
Thank you for your help and time.
Try the path along the axes. Isn't F always zero there?
No it's not.
  • Handwritten derivation of work done by a force field along path A to B then B to C, with integrals of x^2y dx and xy^2 dy, substitutions x = 2a cos θ and y = 2a sin θ, and a final total W = 3a^4 π / 8.
MatinSAR said:
No it's not.
Oh yes it is! (If you familiar with British pantomime.)
Can I expand on what @haruspex said in Post #57?
Referring to the Post #21 diagram, suppose you take the following route:
- from A(0,a), move along the y-axis to the origin (0,0);
- from the origin (0,0) move along the x-axis to C(2a,0).
##\vec F = x^2y~\hat i + xy^2 \hat~j##
While moving along the y-axis (x=0); both components of ##\vec F## are zero.
Similarly while moving along the x-axis.
The total work done along this path is therefore zero. This is different to your calculated value for the original route from A to C.
So you can see (without doing any maths) that the force is not conservative.
Great !
So it's not conserative ...
Thank you.
