Is there a difference in explosive force between successive explosions?
The discussion centers on the differences in explosive force between simultaneous (A) and successive (B) detonations of charges within a single casing. It concludes that while the overall energy release remains constant, the shockwave produced by successive detonations can be directed more effectively, enhancing the impact in a specific direction. This technique is commonly utilized in applications such as tunneling and rock fracturing. The concept of "free expansion" in explosions is also highlighted, emphasizing the importance of charge placement and timing for optimal results.
  • Understanding of explosive physics and energy release mechanisms
  • Knowledge of shockwave propagation and its effects
  • Familiarity with tunneling techniques and rock fracturing methods
  • Basic principles of detonation sequence and timing
  • Research "shockwave focusing techniques in explosives"
  • Study "tunneling methods using sequential detonations"
  • Explore "multi-chamber gun designs and their applications"
  • Investigate "the physics of free expansion in explosive charges"
This discussion is beneficial for explosive engineers, mining professionals, and anyone involved in demolition or construction that requires optimized explosive applications.
Den Webi
Suppose there are two explosive charges in a single casing. The detonation of the charges can be initiated either simultaneously (A) or in succession some milliseconds apart (B).
Does A differ from B in respect to the overall explosive force?
Can the shock front in B carry more energy in a certain direction?
This question arose from my friend's statement that a successive detonation improves the effect of an explosion due to some kind of self amplification process, something that I doubt.
Thank you in advance for your responses!
How do you define "overall explosive force"?
You can get a better shockwave in one direction if you fire the explosions with the right delay. This is frequently used to dig tunnels, or to fracture large areas of rock in mines.
Likes davenn and Den Webi
Energy release is the same.
Den Webi said:
direction?
An ideal "free" explosion is releasing energy in a spherically symmetric manner. Bore a hole, tamp it with clay, and the "free expansion" is forced to do work. Tamp one charge with the pressure wave from another charge, and it's got something even more solid to push against while doing work.
Likes Den Webi
Thank you MFB and Bystander!
Also similar: multi-chamber guns.
http://en.wikipedia.org/wiki/V-3_cannon
Likes Den Webi
  • · Replies 30 ·
  • · Replies 44 ·
15K
  • · Replies 21 ·
