Is there a method for the simplex algorithm that avoids cycling?
  • Thread starter Thread starter wanderlust.xx
    Algorithm Method
The discussion centers on whether the simplex algorithm can be implemented to avoid cycling. It is noted that the standard approach uses the largest coefficient rule for selecting the entering variable, which can lead to cycling. Suggestions for alternative strategies include exploring "lexicographic ordering" and "Bland's Rule" as potential solutions. However, the original poster expresses difficulty in finding a definitive method to avoid cycling. The conversation highlights the need for further research on these strategies to understand their effectiveness in preventing cycling in the simplex algorithm.
wanderlust.xx
"There exists an implementation of the simplex algorithm that avoids cycling. (If your
answer is `yes', describe the strategy; if your answer is `no' give an example and explain
briefly why every strategy must fail.)"
We normally do the simplex algorithm using the largest coefficient rule for the entering variable.
I would assume that to avoid cycling, we simply change this to another procedure, although I have tried to research this in both a book I have here and on the internet to no avail... I'm not sure how to go about doing this question! :(
Look up "lexicographic ordering" and "Bland's Rule".
RGV
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
