Is there a minimum unit of time in string theory?
hamlet69
do string make time or does time make strings , since strings have varoius vibrations, do there have a decay rate? just a question maybe one of you might know an answer?
strings do not make time in ordinary string theory. They exist in spacetime and participate in the time from that. I don't know about decaying vibrations in strings. In fact I think it's only recently that anyone has worked on strings at a finite temperature, where you might discuss entropy. This is all just a rumor to me, perhaps someone more learned will chip in.
I think it depends on if time is relative. Does time require measurement or does it exist outside of that measurement?
Has anyone thought to define time in terms of string theory? Or is it taken for granted and still measured as it is?
Just posted a thread of defining time in string theory. The title is "minimum time" and its found in this (Strings, Branes and LQG) forum. In gist, the smallest unit of time is the Planck time (defined as the amount of time it takes light to travel a Planck distance). Since a string is a Planck length in size, it cannot fit into a smaller space. Therefore, when a photon travels through a Planck distance, it takes up the whole space and can only be defined as a whole string within that amount of time, no less. In other words, if all matter is manifested as a vibrating string, it cannot exist without defining a whole string.
Thread 'LQG Legend Writes Paper Claiming GR Explains Dark Matter Phenomena'
A new group of investigators are attempting something similar to Deur's work, which seeks to explain dark matter phenomena with general relativity corrections to Newtonian gravity is systems like galaxies. Deur's most similar publication to this one along these lines was: One thing that makes this new paper notable is that the corresponding author is Giorgio Immirzi, the person after whom the somewhat mysterious Immirzi parameter of Loop Quantum Gravity is named. I will be reviewing the...
I seem to notice a buildup of papers like this: Detecting single gravitons with quantum sensing. (OK, old one.) Toward graviton detection via photon-graviton quantum state conversion Is this akin to “we’re soon gonna put string theory to the test”, or are these legit? Mind, I’m not expecting anyone to read the papers and explain them to me, but if one of you educated people already have an opinion I’d like to hear it. If not please ignore me. EDIT: I strongly suspect it’s bunk but...
https://arxiv.org/pdf/2503.09804 From the abstract: ... Our derivation uses both EE and the Newtonian approximation of EE in Part I, to describe semi-classically in Part II the advection of DM, created at the level of the universe, into galaxies and clusters thereof. This advection happens proportional with their own classically generated gravitational field g, due to self-interaction of the gravitational field. It is based on the universal formula ρD =λgg′2 for the densityρ D of DM...
