Is there a phase shift associated with twisted nematic LCDs?
Light entering a twisted nematic liquid crystal display (TN LCD) does experience a phase shift when voltage is applied, as the twisting of polarization creates a difference in the refractive index for right and left-polarized light. This phase difference is significant for applications like beam steering. The overall change in the index of refraction may also affect the total phase shift, complicating calculations. The discussion highlights a project involving programmable micromirror devices that require specific phase changes in light, with interest in utilizing a TN device for this purpose. Further connections to experts in this field were requested for deeper insights.
JohnDoes
Hello,
As it says in the title, I would like to know if the light entering a twisted nematic liquid crystal display experiences any kind of phase shift specifically when applying a voltage to manipulate the polarisation of the light.
If it is the case, could someone point me towards any articles that describe this? I have had a look myself on Google etc., though most of the papers that seem related are only accessible through membership.
Also, if anyone knows the sort of maths behind it e.g. applying x amount of voltage/polarisation induces y amount of phase shift, whether it applies for a specific TN LCD device or in general, that would be great.
Thank you.
Yes. There is almost definitely a shift. Twisting of polarization is equivalent to having difference of refraction index for right-polarized and left-polarized light. (See Faraday Effect for some details.) So I would expect a difference in phase between on and off states. But there might be an overall index of refraction change as well, so I have no idea how you'd go about estimating the total.
I can tell you that people would be looking into this, because there have been applications of liquid crystals in beam steering, where phases are really important. I could probably even point you to people who would know, depending on how important this is.
Thank you for the reply K^2. I ask this particular question because it regards a particular design project that I am working on. My project involves finding some programmable "micromirror" device that can create bespoke changes for the phase of light. I happen to have access to a projector that uses a TN device; if it does the stuff I need it to do, with some reverse engineering, it could be just the thing.
If you could point me towards anyone who knows more I'd appreciate it.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
