Is There a Reactive Force on Radiant Electromagnetic Energy?
In summary, the conversation deals with the question of whether there is a reaction force on radiant electromagnetic energy due to its interaction with charged particles, and how this reaction would manifest. The conversation also touches on the relationship between classical mechanics and special relativity in explaining this phenomenon, and includes a link to a simulation and a discussion on the Larmor formula and Thomson scattering. Ultimately, it is concluded that the electron cloud is responsible for the movement and radiation, rather than the nucleus.
Philalethes
Hello,
In electrostatics, classical mechanics predicts that a charged particle's action-at-a-distance force (Coulomb's law) on other charges is accompanied by an equal and opposite reaction force on the particle.
Classically, radiant electromagnetic energy is a self-propagating electromagnetic field; therefore, must there likewise be a reaction force on this radiant energy resulting from its action on charged particles? If so, how would this reaction manifest? Would this mean a decrease in energy of the radiant EM energy? Does it slow down? Change its path? Is it explainable without significant explanation of special relativity or any QED?
Thanks,
Philalethes
Science news on Phys.org
You may be interesed in a simulation of the field lines of a moving point charge, using the Cal Tech simulation tool at http://www.cco.caltech.edu/~phys1/java/phys1/MovingCharge/MovingCharge.html
The first panel shows the field lines of a charge moving at a velocity β = 0.5 from the left to the right. The field lines are straight, and slightly compressed toward the 90 degree line (due to length contraction along direction of motion). The lines move out away from the charge at β=1 in the reference frame of the observer.
In the second panel, a charge moving at β = 0.5 is suddenly decelerated to β = 0.225. This produced a kink in the field lines, which also radiates out away from the moving charge at β = 1 in the reference frame of the observer. Any observer at a distance [itex] \ell [/itex] from the particle will see a retarded signal at delayed time [itex] \delta t = \ell / c \space [/itex].
So the E field lines for a constant velocity charge are a longitudinal E field (i.e., radial), while the E field in the kink of the decelerated charge is transverse. Does this mean that the lost energy is being radiated as a pulsed TEM field?
Here is the caption to the applet
When the charge moves at relativistic speed, the electric field is concentrated near the pole, and consequently the field lines are shifted. The field lines always point to where the charge is at that instant, if we are within the current sphere of information. If that charge has changed speed or direction within a time t < r/c, where r is the distance away, and c is the speed of light, we will not know that charge has accelerated, and the field lines will still point to where the charge would be if it hadn't changed speed or direction.
Notice That when the charge is accelerated, because the field lines must be continuous, it is forced in a direction almost perpendicular to the the direction of propogation. As time goes on, the line becomes more and more perpendicular, the horizontal component increasing faster than the vertical component. Associated with this electric field is a magnetic field, perpendicular to the electric field and the direction of propogation, which describes light.
The classical radiation (radiated power) from a decelerating charged particle is given by
[tex] \frac{dW}{dt}=-\frac{e^2 \dot v^2}{6 \pi \epsilon_o c^3} [/tex]
where [itex] \dot v [/itex] is the acceleration. This radiation moves away from the charged particle at β = 1.
See Panofsky and Phillips Classical Electricity and Magnetism page 301.
Thank you Bob, for pointing me toward the Larmor formula. I found this document from the Wikipedia article about it. In section 5.2, he uses the example of blue light scattering in the atmosphere as a demonstration of energy conservation as light passes by an atom, but declines to explain the exact mechanism behind the decrease in energy of the light! (See attachment screenshot of the PDF)
I'm looking over your first post again to see if the answer is contained therein...
Kinematically, scattering light off of an atom is just like Thomson scattering off of a single electron, which is the classical limit of Compton scattering. Look specifically at the derivation of this formula for the wavelength shift in http://en.wikipedia.org/wiki/Compton_scattering
[tex] \lambda'-\lambda=\frac{h}{mc}\left(1-\cos\theta \right) [/tex]
where m is the mass of the electron and θ is the scattering angle. In Rayleigh scattering, the recoil mass is the entire atom, so let's cosider scattering at 90 degrees. We have
[tex] \lambda'-\lambda=\frac{h}{Mc}=\frac{hc}{Mc^2}[/tex]
Using hc = 4.136x 10-15 eV-sec x 3 x 1010cm/sec = 1.24 x 10-4 eV -cm, and Mc2=1.3 x 1010 eV for a nitrogen atom, we get
[tex] \lambda'-\lambda=\frac{hc}{Mc^2} = \frac{1.24 x 10^{-4} eV \cdot cm}{1.3x10^{10} eV}=9.5 x 10^{-15}cm = 9.5 x 10^{-7} Angstroms[/tex]
So there is a wavelength shift, but it is very small.
Incidentally, the author of the paper you referenced implied that the nucleus was moving and radiating. It is actually the electron cloud that is moving and radiating.
Thanks! Thomson scattering describes what I was looking for.
Philalethes
Related to Is There a Reactive Force on Radiant Electromagnetic Energy?
1. What is reactive force on radiation?
The reactive force on radiation is the force exerted by electromagnetic radiation on a surface or object. It is caused by the momentum transfer from the photons of the radiation to the surface or object.
2. How does reactive force on radiation affect objects?
The reactive force on radiation can cause objects to move or accelerate, depending on the direction and intensity of the radiation. It can also cause changes in the temperature or properties of the object, such as ionization or vibration.
3. What is the relationship between reactive force on radiation and the properties of the object?
The reactive force on radiation is influenced by the properties of the object, such as its mass, surface area, and reflectivity. Objects with a higher mass or larger surface area will experience a greater reactive force, while objects with higher reflectivity may experience a lower reactive force.
4. How is reactive force on radiation measured?
The reactive force on radiation can be measured using instruments such as a radiation pressure balance or a radiometer. These instruments measure the pressure or force exerted by the radiation on a surface or object.
5. Can reactive force on radiation be harnessed for practical use?
Yes, reactive force on radiation can be harnessed for practical use in various applications such as solar sails, laser propulsion, and radiation pressure-based engines. However, these technologies are still in the early stages of development and require further research and advancements.
  • Electromagnetism
  • Thermodynamics
  • Classical Physics
  • Thermodynamics
