Is there a way to turn on/off the flow of water on this water clocK?
  • Thread starter Thread starter Moedangel
    Clock Flow Water
To modify a water clock for adjustable flow, consider adding a tap or spigot to control the water release. Blocking air flow in one of the tubes could also reduce the water flow to a drip, which may help in timing longer intervals. Adjusting the clock's shape could improve accuracy in measuring water depth. The goal is to create a device that functions more like a stopwatch rather than a traditional timer. Implementing these modifications can enhance the clock's functionality for physics experiments.
Moedangel
The water clock in question is this:
I currently have to build a timer for my high school physics class. I plan on using a very similar design structure as shown in the video. However, I would like to know if there is a mechanism/modification I can do to this so that I can stop/greatly reduce the flow of water by pulling/twisting/switching something. My goal is to make this device acts more like a stopwatch than a timer.
No equations come to mind.
Currently, I'm thinking the best way to do it is to somehow block the flow of air from one of the tubes so that the water slows down to a drip. I'm having a hard time figuring out how to do it though.
Add a tap or a spigot.
You've thought of that right?
If you want to slow it down that suggests you want to time long intervals? Normally to do that you count how many times you have to turn it over.
If you do it by slowing down the rate you may also want to change the shape so you can measure the depth of water more accurately.
