Is there any command in Fortran that is similar to eval in MATLAB?
  • Thread starter Thread starter phanlada
    Fortran Matlab
Fortran does not have a direct equivalent to MATLAB's eval function for dynamically calling functions by name. Instead, users can define the function directly within the main program or encapsulate it in a MODULE, which can then be included in the main program. This allows for straightforward function calls without the need for dynamic evaluation. The discussion emphasizes using standard Fortran practices to achieve similar functionality. Understanding these methods is essential for implementing Newton's method for solving non-linear equations in Fortran.
phanlada
Hello,
I am trying to write a Fortran subroutine to solve non-linear equations (given by external function fnxname) using Newton's method, where the derivative is given by finite difference calculation. How may I use the function in the program.
Suppose the desired function name is given by a string "fnxname", I cannot write fnxname(x), can I? In MATLAB, I may write eval(cat('fnxname','(x)')) or something like that. Is there a similar command in Fortran?
Replies would be much appreciated. Thank you very much.
You can either just put the function inside of the main program's file, or put the function inside of a MODULE and INCLUDE that module in the main program. Then you can simply call the function as normal.
10K
9K
