Is there any effect of wire's insulation on it's magnetic an
  • Context: Undergrad
  • Thread starter Thread starter dumbboy340
    Insulation Magnetic
The discussion centers around the effects of wire insulation on electric and magnetic fields, exploring whether and how insulation influences electromagnetic interactions. Participants examine the implications of insulation in various contexts, including transmission lines and coaxial cables.
  • Exploratory, Technical explanation, Debate/contested
  • Some participants question whether insulation affects electric and magnetic fields, with one asking for clarification on how magnets interact with insulated wires.
  • One participant notes that insulation affects the electromagnetic propagation speed along a wire, particularly in transmission lines, referencing the concept of Velocity Factor (VF).
  • Another participant expresses uncertainty about the effect of magnetic fields on insulation, indicating a need for further research.
  • It is suggested that insulation primarily affects electric fields rather than magnetic fields, due to its dielectric properties.
  • One participant points out that while typical insulation materials have low magnetic permeability, a sheath in coaxial cables can influence the magnetic field due to its high permeability.
Participants express differing views on the extent to which insulation affects magnetic fields, with some asserting minimal impact while others suggest that certain configurations, like coaxial cables, may have significant effects. The discussion remains unresolved regarding the overall influence of insulation on magnetic interactions.
Participants reference specific properties of materials, such as dielectric constants and magnetic permeability, but the discussion does not reach consensus on how these properties translate to practical effects in various scenarios.
dumbboy340
Does insulation affect electric and magnetic field?
What's the purpose of insulating a wire?
That is what I'm asking.If it does,why a magnet interacts it?i'm confused.please explain it??
Insulation does affect the EM propagation speed along the outside of a wire
This becomes very apparent with transmission lines ( antennas) that have either a covering
The result is a slowing of the EM propagation, This is known as the VF -- Velocity Factor
Dave
I'm not sure that a magnetic field on its own is affected by insulation
That I would have to research
Why do you think a magnetic field interacts with insulation? It does not. As stated already, insulation has a higher dielectric constant than air, so it will affect the E field generated by voltages on the wire (including the velocity factor that Dave has mentioned).
Thanks!
I guess if you're counting a sheath (like in coaxial cable) as the insulation, then it certainly affects the [itex]B[/itex] field produced by the wire because the metal intentionally has high permeability. Otherwise plastic wouldn't have a noticeable effect.
  • · Replies 22 ·
  • · Replies 17 ·
