Is there any solution to the equation x^(0.5)+1=0?
  • Context: Undergrad
  • Thread starter Thread starter Alan Lugano
The discussion centers around the equation x^(0.5) + 1 = 0, exploring whether there are any solutions, particularly in the context of real and complex numbers. Participants examine the implications of squaring both sides of the equation and the nature of solutions in the complex plane.
  • Some participants assert that there are no real solutions to the equation, while others explore complex solutions by assuming x takes the form e^(ix/2).
  • One participant proposes that if x is an imaginary number, the equation can be solved to yield x = 2(2πn + π) for integer n, leading to confusion about the nature of the solutions.
  • There is a discussion about why substituting x = 1 does not satisfy the equation, with some arguing that it leads to a contradiction (2 = 0).
  • Participants debate the implications of squaring both sides of the equation, with some stating that it leads to x = 1, while others challenge this reasoning.
  • Several participants discuss the principal square root convention, noting that by convention, √1 = +1, which complicates the assertion that 1^(0.5) + 1 = 0.
  • There is a clarification that while z = e^(i·2π) is a real number, the square root operation introduces complexity, leading to confusion about whether the equation has real solutions.
  • Some participants emphasize that the domain of the function affects the interpretation of the solutions, particularly regarding the graph of y(x) = 1^x.
Participants generally disagree on the existence of solutions to the equation, with multiple competing views on the nature of solutions in both the real and complex domains. The discussion remains unresolved regarding the implications of squaring both sides and the interpretation of principal square roots.
Limitations include assumptions about the domain of the functions involved, the interpretation of complex numbers, and the conventions surrounding square roots. The discussion reflects a range of mathematical reasoning without reaching a consensus.
Alan Lugano
I got myselft wondering if there is any solution to the equation x^(0.5)+1=0. I know that for a real x there is not but, when I assume x is any imaginary number in the form e^(ix/2) and then solve the equation e^(ix/2)=-1 the result is x=2(2 pi n + pi) for integer values of n. If one then takes n=1, x=6pi and e^(i 6pi) = 1. Whaaaat?
My other question is why in an equation like the one above, squaring both sides to get the solution is not allowed since it would result in x=1.
Mathematics news on Phys.org
Why isn't ##1## a solution ?
Hello Alan, :welcome:
You mean 'of the form ##e^{ix}## '
You mean 'and ##e^{3\pi} = -1## '
Question is: is ##e^{6\pi}## in the domain of the function, or is the domain limited to arguments ##[0, 2\pi)## or perhaps ##(-\pi , \pi]## ? Read about it here
(I only get to see the animation when I open the picture in a new tab)
Well I think that once you substitute x=1 in the equation you would get:
1^(0.5) + 1 = 0
2=0 ?
Am I missing something?
BvU said:
Hello Alan, :welcome:You mean 'of the form ##e^{ix}## '
Thank you for the answer and the greeting! Let me put it differently:
I have the equation:
##x^{0.5}## +1 = 0
So I assume that ##x=e^{iy}## and then I get that ##e^{iy/2}+1=0##
From the Euler's identity I have a solution in the form ##y=2\pi##
So ##x=e^{2\pi i}## which gives ##x=1## and therefore ##1^{0.5}+1=0##. Where am I missing something?
1^(0.5) + 1 = 0
2=0 ?
No you are correct but also ##(-1)^2 = 1## so ##1^{1/2} = \pm 1##. Or ##1^{1/2} + 1 = -1 + 1 = 0##.
You were told to find the solutions to the equation.
But if you graph the function ##y(x)=1^{x}## and look at the point ##x=0.5## you will get y=1. In the other hand, if you graph ##(-1)^{x}## you will get ##y=i##. So how can you affirm that ##1^{1/2}+1=-1+1=0##??
Are you saying that you don't believe that ##(-1)^2 = 1## ?
When you graph a function, the graph will be on the domain and range of the function. For the function ##f(x) = \sqrt{x}##, the domain and range is ##x\ge 0## (by convention for range).
You are given to find the solutions to a equation not roots of a function ##f(x) = \sqrt{x} + 1##.
Alan Lugano said:
But if you graph the function ##y(x)=1^{x}##...
The graph of ##y = 1^x## isn't very interesting, assuming x and y are real numbers. 1 raised to any finite power is just 1, so the graph is just a horizontal line through (0, 1).
By convention ##\sqrt{1} = + 1##, ##\sqrt 4 = + 2##, NOT ##\pm 1## or ##\pm 2##, respectively. By extension, ##1^{1/2} = \sqrt 1##.
If ##z = e^{i\cdot 2\pi}## = 1 + 0i, then the principal (complex) square root is ##e^{i \cdot \pi}## = -1 + 0i. So this value of z is a solution to the equation ##z^{1/2} = -1##, or equivalently ##z^{1/2} + 1 = 0##.
I am using z to reinforce the idea that I'm working with complex numbers.
When you wirte ##z=-1+0i## aren't you saying this is a pure real number once the imaginary part is zero? If so, is it right to say that the equation has a real solution. This is very confusing to me.
z here has no imaginary part, but ##z^{1/2}## is complex, and that is what the equation involves.
Reason for that convention is that to fit ##\sqrt{x}## in functions but that does not matter when solving a equation.
You are mistaken.
In the real numbers, ##\sqrt x = 2## has one solution -- x = 4.
No, it comes from solving equations.
Suppose we are given ##a \geq 0## and we wish to find ##x \in \mathbb{R}## such that ##x^2 = a##. Then we show:
  1. If ##a = 0## there only exists one solution, namely ##x=0##,
  2. If ##a \neq 0## then there exists two distinct solutions ##x_1## and ##x_2##,
  3. We involke the fact that the reals have a total ordering, so that either ##x_1 > x_2## or ##x_1 < x_2##.
  4. We prove that ##x_2 = -x_1##.
After doing all that, we conclude that one of the two solutions is positive and the other is negative. We define the notation ##\sqrt{a}## to be the positive value and call it the principle square root. Due to 4, the other root is then ##-\sqrt{a}##.
Further, it's easy to see that "that does not matter when solving a equation" is a false statement by just looking at the quadratic formula. If ##\sqrt{a}## meant both positive and negative the formula would never have the ##\pm## sign in it.
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 19 ·
