Is there so-called "optimal traction" for vehicles?
  • Context: Undergrad
  • Thread starter Thread starter Jinjolee
    Traction Vehicles
The discussion centers on the concept of "optimal traction" in vehicle design, emphasizing the balance between road grip and steering ease. Key factors influencing traction include tire material, with racing tires prioritizing grip over longevity, while consumer tires focus on a compromise between grip and tire life. The conversation highlights that high traction can lead to steering difficulties and potential road damage, but the optimal traction level varies based on vehicle purpose and driving conditions. Ultimately, there is no universal optimum; it is context-dependent, influenced by factors such as fuel consumption and individual preferences.
  • Understanding of tire materials and their properties
  • Knowledge of vehicle dynamics and traction concepts
  • Familiarity with driving conditions and their impact on tire performance
  • Awareness of the trade-offs between performance and cost in vehicle design
  • Research the impact of tire compounds on traction and wear
  • Explore the role of tire tread patterns in various weather conditions
  • Investigate advancements in power steering technology to mitigate steering difficulties
  • Examine case studies on consumer preferences regarding traction versus fuel efficiency
Automotive engineers, tire manufacturers, vehicle designers, and anyone interested in optimizing vehicle performance and safety through traction management.
Jinjolee
Consider for vehicle, a low traction indicates a lower road grip, which leads to a skid easier; a high traction makes the vehicle difficult to steer, and also damages both road and tire.
So I am wondering if there is a balance point of the traction in vehicle design such that it is at an optimal state?
Free feel to point out anything i got wrong above. Thanks.
Hello and welcome to PF.
Compromise is the key word here.
For a given wheel and tyre size, a huge factor governing traction is the tyre material. The material for a domestic vehicle tyre is a compromise between adequate grip and tyre life. The optimum for a racing tyre is different. They are expected to wear out within the time of a single race because they need very good grip.
Then there is the compromise for driving conditions. On a dry track, slicks give best traction (no tread) but when there is any water on the track, a grooved tread is needed to push water aside and give a good contact with only half the area.
Yes, high traction can result in a fragile tire. The compound used in racing tires is soft and sticky. Crumbles can peel off of it.
Yes, high traction can result in road damage. Putting studs or chains on a snow tire can result in road damage.
It is not clear that there is serious motivation to trade away good grip to gain easier steering, however. Can you give an example?
There is not one optimum. It depends on the vehicle's task. For normal consumer cars fuel consumption is a major issue.
Optimal requires a value judgement for "best". Clearly, a government dealing with highway repair budget, will disagree with salesmen of studded tires, about how to define "best".
Even for individual people, the trade-off between performance and price is not something that everyone will agree on.
An example would be steering while the car is stopped. But I also don't think that this is a relevant consideration.
Thanks for your answers.
So could i say "we always want a higher traction for cars to grip the road and prevent skidding. And if this traction is high enough to hinder motions(e.g. hard to steer), we would consider other approach to overcome this problem(e.g. Power steering), instead of decreasing the traction"?
High traction doesn't make a car difficult to steer if the car is moving. For public roads, the main case I can think of for steering while a car is stopped is part-way through a parallel parking sequence, and it's unlikely to put much wear on the road or tires. If you look at asphalt roads that show signs of wear, the main locations of deformation are at intersections, due to braking and acceleration. You don't see this type of deformation on streets with parallel parking.
Jinjolee said:
...hard to steer...
Didn't we just explain to you, that this is not a relevant issue?
  • · Replies 26 ·
  • · Replies 69 ·
16K
