Is this a possible idea for an antimatter rocket engine?
Antimatter can theoretically be contained in magnetic fields, leading to the idea of using a magnetic nozzle to propel thrust from antimatter-matter annihilation reactions. However, significant limitations exist, including the challenges of stabilizing antimatter in a magnetic field and the immense energy release from these reactions, which could be difficult to manage. The concept does not violate any laws of physics but remains largely theoretical due to current technological constraints. The discussion acknowledges that while the idea may seem impractical, it reflects correct thinking about propulsion methods. Overall, the potential for antimatter propulsion is intriguing but faces substantial hurdles before becoming feasible.
rmoh13
Antimatter can be contained in magnetic fields; what if we could somehow "propel" that magnetic field by using a magnetic nozzle when the small antimatter-matter reactions/annihilation occurs which produces thrust? This seems like a really stupid idea, but can you tell me some limitations about this idea like whether or not it violates some laws of physics or if this reactions are too much to handle or if we can't "stabilize/hold" antimatter in a magnetic field. etc.? Thank you.
EDIT: This was a super stupid question, I should've just gone onto Wikipedia, my dumb question was answered!
Science news on Phys.org
Borg said:
Maybe this wiki article will help - Antimatter rocket.
Thank you!
Not a dumb question -- you just thought of something that works (theoretically, in this case), but someone else already thought of. That's going to happen a lot to you, but at least it means you are thinking correctly/in the right direction. It's a lot better than thinking something that doesn't work!
Likes rmoh13
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
