Is this a valid operation (integration by parts)?
jam_27
Say I have a function,
f(x) = x sec (f(x)) [this is just an example function, the actual problem is more complicated]
g(x) = x f(x), then using integration by parts, I can write
I = abg(x) dx = abx f(x) dx = (f(x) \frac{x^{2}}{2})|^{b}_{a}- \frac{1}{2}ab\frac{d f(x)}{dx} x2 dx
Then can I write the integral as (cancelling dx from the numerator and denominator in integral on the RHS)?
I = (f(x) \frac{x^{2}}{2})|^{b}_{a}- \frac{1}{2}f(a)f(b) x2 df
or,
I = (f(x) \frac{x^{2}}{2})|^{b}_{a}- \frac{1}{2}f(a)f(b) f2 cos2 (f) df ?
This is simplified version of my actual problem. So any inputs will be very useful?
PS: I have edited the originally posted problem definition as it was causing confusion.
So you need to find the integral
-\int_a^b xW(-x)dx
where ##W## is the Lambert W-function?
What kind of answers are acceptable? A closed form solution? A series solution?
Wolfram alpha gives the following:
\int - x W(-x)dx = \frac{x^2(1 - W(-x))(2W(-x)^2+1)}{8W(-x)^2}
which in term of your notation would be
\frac{x^2(1 + f(x))(2f(x)^2 +1)}{8f(x)^2}
I know about the Lambert W-function. As I said, above is a simplified version of my actual problem. so I specifically need to know if my last 2 steps are valid operations. Thanks
OK.
I think this is ok.
I = (f(x) \frac{x^{2}}{2})|^{b}_{a}- \frac{1}{2}f(a)f(b) \frac{f}{e^{f}}df ?
Any reason why you don't have ##f^2/e^{2f}##? You have ##x = \frac{f(x)}{e^{f(x)}}## and thus ##x^2 = \frac{f(x)^2}{e^{2f(x)}}##. No?
Likes 1 person
Thanks, I have corrected the typo and also the original problem definition. Please see if its ok now.
Seems fine to me.
