sarah22 said:
So it is not a vector space because when you multiply it to a negative scalar, it will go down to the 3rd quadrant?
That's right.
sarah22 said:
Isn't it adding negative vector would make it go outside the 1st quadrant? So it should follow that also?
Yes, it's another of the rules for a vector space that every vector in the set must have an additive inverse in the set. That means, for every vector
u in the set, there must be some vector
v, also in the set, such that
u +
v =
0 (the zero vector); that's to say,
v = -
u. In other words for every vector
u, there is some vector -
u. But this isn't the case for the set of vectors belonging only to the first quadrant of R
2, so it can't be a vector space.
On the other hand, the set of vectors he's asking about all have a positive x component and a positive y component. If you add anyone of these vectors to any other, the resulting vector will still be in the first quadrant. It's true that adding either of the vectors (-1,0) or (0,-1), or any linear combination of these, to any vector (x,y) in this set would result in a vector not in the set, but this isn't a problem because neither (-1,0) nor (0,-1) belong to the set he's asking about (the first quadrant of R
2).
sarah22 said:
If I understand it correctly, for it to be called a vector space it must follow the rule that when you multiply and adding it to all real scalar, the resulting vector should be inside the vector space?
When you multiply a vector in the set by a scalar, the resulting vector has to be in the set. Also when you add any vector in the set to any other vector in the set, the resulting vector has to be in the set. (But adding a scalar to a vector isn't defined.) A general name for this property is "closure"; the set is said to be "closed under" some operation (in this case closed under scalar multiplication and vector addition) if the result belongs to the set.
sarah22 said:
Sorry if I'm wrong. I'm studying it on my own and my brain can't pick up what he said about the vector space. :(
Don't be sorry! Asking questions and testing out whether you've got them right is a great way to learn. I'm studying on my own too. A few months ago I didn't understand much. I remember when I watched lecture one of that series for the first time it made no sense to me at all! I think it's starting to get clearer, although I still have a lot to learn (I got up to lecture 13, but I took a break to do some background reading...), so hopefully more knowledgeable people here can correct me if I've made any mistakes.
