Is this general solution for ODE correct?
andrey21
Find the general solution of the following ODE:
dx/dt = 3x^(2) cos t
Make x the subject of the solution.
Heres my solution, is this correct?
dx/3x^(2) = cos t dt
Integrating both sides gives:
ln (3x^(2)) = sin t + C
3x^(2) = e^(sin t + C)
3x^(2) = Ae^(sin t)
x^(2) = (Ae^(sin t))/3)
x = SQRT(Ae^(sin t))/3)
here is where you went wrong,
1/3x2 can be written as x-2/3.
You know that ∫xn dx = xn+1/(n+1) + C for n≠-1
So from what you have said:
∫dx/3x^(2) = -1/3x + C or (-x^(-1)/3) + C
Giving a solution of:
-1/3x + C = sin t
That should be correct.
You can easily check your answer by plugging it back into the original differential equation and seeing if it works.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
