MHB Is this equation true for positive values of x and y?
  • Thread starter Thread starter cbarker1
    Property
The equation $y^2+x*\sqrt{4x^2+y^2}=y^2+\frac{x}{y}*\sqrt{4(\frac{x}{y})^2+1}$ is not true for positive values of x and y. The left side simplifies to $y^2+x \cdot |y| \cdot \sqrt{ \frac{4x^2}{y^2}+1}$, which, under the condition that y is positive, becomes $y^2+x \cdot y \cdot \sqrt{ \frac{4x^2}{y^2}+1}$. This indicates that the two sides of the equation do not equate as initially proposed. The discussion confirms the need for careful evaluation of mathematical expressions involving square roots and ratios. The conclusion is that the equation does not hold true for the specified conditions.
cbarker1
MHB
Hello,
I need some aid to see if this true:
$y^2+x*\sqrt{4x^2+y^2}=y^2+\frac{x}{y}*\sqrt{4(\frac{x}{y})^2+1}$ provide that y>0 and x>0.Thank you,
Cbarker1
Mathematics news on Phys.org
Cbarker1 said:
Hello,
Cbarker1
(Wave)
No. It holds that $y^2+x \cdot \sqrt{4x^2+y^2}=y^2+ x \cdot \sqrt{y^2 \left( \frac{4x^2}{y^2}+1\right)}=y^2+x \cdot |y| \cdot \sqrt{ \frac{4x^2}{y^2}+1}$.And provided that $y>0$, $y^2+x \cdot |y| \cdot \sqrt{ \frac{4x^2}{y^2}+1}=y^2+x \cdot y \cdot \sqrt{ \frac{4x^2}{y^2}+1}$
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
