Is ULN2064B Safe for 24V Stepper Motors?
The discussion centers on the use of the ULN2064B integrated circuit for controlling 24V stepper motors, specifically addressing concerns about the current requirements and safety of the setup with respect to the IC's specifications.
  • One participant inquires whether 800mA is a correct current requirement for the 24V stepper motors and if the ULN2064B can safely handle this current.
  • The same participant notes that the output of the ULN2064B is inverted, indicating that a logic 0 is needed to activate a motor coil.
  • Another participant requests the datasheet for the ULN2064B to clarify its voltage and current ratings and to check for application circuit diagrams related to driving stepper motors.
The discussion does not reach a consensus on the safety of using the ULN2064B with the specified stepper motors, as there are questions about the current ratings and the need for further information from the datasheet.
There are limitations regarding the missing specifications from the datasheet, which are necessary to fully assess the compatibility of the ULN2064B with the stepper motors.
monahago
Hi All
I am using a ULN2064B to control 2 stepper motors, and the input to the IC is directly from an I/O port on an 8051 microcontroller.
The stepper motors are 24V, and "apparently" need 800mA each to operate. Does this sound correct? And is this safe with the ULN2064B?
Basically, as I am aware the output is inverted, so to turn a coil from a motor on I apply a logic 0 to the corresponding input pin on the 2064B
Any help would be great.
Cheers guys
iam really sorry please forgive me all
No worries, you were just a little confused about where/how to post.
Could you supply a pointer to the datasheet for your IC? What are its voltage and current ratings? Does it show an application circuit diagram for driving a stepper motor?
i need asoftware(windows XP) to calculate the sun position ,the enteries should include the longitude to tenth of a second , time to the second and altitude.The utility is to produce the azimuth and elevation to the center of the sun to an accuracy of 0.1 degrees and better if pssible,the simpler the better.
thank you for your time
Thank you berkeman
I googled sun azimuth elevation calculator, and got lots of hits. Here's the hit list:
http://www.google.com/search?source...US301US302&q=sun+azimuth+elevation+calculator
You could also change the word calculator to software in the google search, to get more general links.
  • · Replies 19 ·
