Is ULN2064B Safe for 24V Stepper Motors?
The discussion centers on the use of a ULN2064B to control 24V stepper motors requiring 800mA each. Concerns are raised about the safety and compatibility of the ULN2064B with these specifications, particularly regarding its output characteristics and current ratings. Participants suggest checking the datasheet for voltage and current limits and inquire about application circuit diagrams for stepper motor control. The conversation briefly diverges into unrelated topics, including requests for software to calculate sun position. Overall, the main focus remains on ensuring the ULN2064B can safely operate the specified stepper motors.
monahago
Hi All
I am using a ULN2064B to control 2 stepper motors, and the input to the IC is directly from an I/O port on an 8051 microcontroller.
The stepper motors are 24V, and "apparently" need 800mA each to operate. Does this sound correct? And is this safe with the ULN2064B?
Basically, as I am aware the output is inverted, so to turn a coil from a motor on I apply a logic 0 to the corresponding input pin on the 2064B
Any help would be great.
Cheers guys
iam really sorry please forgive me all
No worries, you were just a little confused about where/how to post.
Could you supply a pointer to the datasheet for your IC? What are its voltage and current ratings? Does it show an application circuit diagram for driving a stepper motor?
i need asoftware(windows XP) to calculate the sun position ,the enteries should include the longitude to tenth of a second , time to the second and altitude.The utility is to produce the azimuth and elevation to the center of the sun to an accuracy of 0.1 degrees and better if pssible,the simpler the better.
thank you for your time
Thank you berkeman
I googled sun azimuth elevation calculator, and got lots of hits. Here's the hit list:
http://www.google.com/search?source...US301US302&q=sun+azimuth+elevation+calculator
You could also change the word calculator to software in the google search, to get more general links.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
