Is Zero Torque on a Pivot Point Indicative of Zero Force?
  • Thread starter Thread starter Sinister
    Torques
Zero torque at a pivot point does not necessarily indicate that the force acting on it is zero; rather, it suggests that the distance from the pivot to the point where the force is applied is zero. In scenarios where force is applied directly at the pivot, torque will be zero despite the presence of force. The relationship between torque and force is defined by the equation T = F x D, where D is the distance from the pivot. If the distance is small, the resulting torque will also be small, but this does not negate the existence of force. Understanding this relationship is crucial for analyzing torque in experiments involving pivot points.
Sinister
if the torque on a pivot point is zero does that mean the force acting on it is zero aswell?
F = mg and T = F x D
The sum of the torques in this lab that I'm doing isn't equaling zero... is this normal due to error?
I think it has something to do with the pivot point and the torques
T=FD, so either F=0 or D=0. Most times, the distance of the force from the pivot is 0 i.e. the force is directly on the pivot.
ok but for the lab its asking us to measure the force along the pivot point using a scale... and we got a number so how does this affect the torque?
Well right, you might get a value for the force, but if the distance from the pivot is zero, then the torque is zero.
If the distance from the force is small, you will get a small value for the torque as well.
