Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #13,681
tsutsuji said:
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120912/0745_syasin.html Tepco is releasing 600 photographs taken from 11 March 2011 to 28 March 2011. "Because of bad coordination within the company, we were not able to fully grasp the photograph status and were late to release them. It is possible that more unreleased pictures are remaining, so we are checking in order to release them", they explain. Pictures showing accumulated water in power equipment rooms in unit 1 and unit 2 turbine buildings are included.
http://photo.tepco.co.jp/index-j.html [the 600 new pictures are in the links numbered (1) to (40)]
Thanks. I would probably have found some of the photos on this particular page of that collection to be the most interesting if they had been released much earlier. Some (mostly numbers 4 & 11) show that area between reactor 3 & 4 where rather radioactive debris was discovered in a survey, and it looks like these photos are from before they 'bulldozed' over that area/turned the debris into a more concise pile.
http://photo.tepco.co.jp/date/2012/201209-j/120911-31j.html
  • #13,682
Speaking of which, what building is this, does anyone know? Sorry for asking, I know I should have no trouble identifying it, but my memory is acting up again.
http://photo.tepco.co.jp/library/20120911_31/120911_295.jpg
also, is the large pipe in the bottom-left corner a part of the venting system?
http://photo.tepco.co.jp/library/20120911_31/120911_289.jpg
  • #13,683
tsutsuji said:
]27 August 2012 government-Tokyo Electric mid and long term response committee, technical development progress headquarters (8th meeting) ( http://www.meti.go.jp/earthquake/nuclear/20120827_02.html )
Document 2
http://www.meti.go.jp/earthquake/nuclear/pdf/120827/120827_02c.pdf Progress status of development of machinery and equipments to prepare fuel debris removal
https://www.physicsforums.com/showthread.php?p=4064974&posted=1#post4064974 Translation [installment 1: abstract]
https://www.physicsforums.com/showthread.php?p=4068601&posted=1#post4068601 Translation [installment 2: remote decontamination]
https://www.physicsforums.com/showthread.php?p=4069889&posted=1#post4069889 Translation [installment 3: PCV leakage points identification]
Translation [installment 4: PCV repairs]
13/34 1/3
13/34 2/3
13/34 3/3
  • #13,684
14/34
15/34
16/34
  • #13,685
I'm not sure what that building is for, but looking at the high quality aerial images from early on, its the building that is directly west of the shared reactor 3/4 stack tower.
The large pipe is the broken part of reactor 3 vent pipe that got plenty of attention at the time due to showing up so clearly on the same set of aerial photos.
Meanwhile I see they have now removed the reactor cap from the reactor 4 refuelling floor, just like they did with the containment cap:
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120913_03-e.pdf
And they have done a new visual study of reactor 3 pool, or at least the state of the debris that is around the pools surface.
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120913_02-e.pdf
  • #13,686
EDIT: that would be the switching area, according to this:
http://files.abovetopsecret.com/images/member/f9037506eaef.gif
So, yes. thanks, I was not sure. What a clean break, by the way! The bolts sheared and the whole thing just fell off. I wonder how hot it is.
EVEN LATER EDIT: here's another big pipe segment:
http://photo.tepco.co.jp/library/20120911_40/120911_590.jpg
from here
http://photo.tepco.co.jp/date/2012/201209-j/120911-40j.html
SOME MORE PIXEL-HUNTING LATER:
would this
http://photo.tepco.co.jp/library/20120911_39/120911_522.jpg
be the very same switching area? There is debris on the floor, apparently concrete from Unit 3 blowing up.
  • #13,687
I can be wrong but those big concrete pieces under the 'landed' cap looks like the top concrete shielding of the reactor well.
Ps.:
That will be a different pipe, not part of the venting system. You can see it's connections on this photo: http://photo.tepco.co.jp/library/20120911_40/120911_593.jpg
  • #13,688
  • #13,689
a.ua. said:
It traces of tsunami.
No it is not, there is no silt. But upon looking more carefully, it appears that junk from the explosion hit it pretty hard. Some of it made it inside.
  • #13,690
zapperzero said:
<snip>
I'm not 100% sure but it's likely that the joints in the vent pipe are not bolted together as such, the joints have to allow for expansion so it's more like a "slip joint" hence the clean separation.
zapperzero said:
Is that pipe the vertical stack that was attached to the exterior NW corner of [STRIKE]U3 [/STRIKE] U4 perhaps (edit cheers Steve, I should have checked)
would this
EDIT : I'm having a bad day - my mistake - answer should have been no, different building - that interior shot is the Units 1 & 2 UHV switch building. Up on the hill west of Units 1 & 2
impacted by U3 explosion.
  • #13,691
westfield said:
Is that pipe the vertical stack that was attached to the exterior NW corner of U3 perhaps
Yes, but reactor 4 not reactor 3.
  • #13,692
No visible tsunami damage to that building. The corner that is opened up is actually closer to unit 4. The images are not the best but it seems there might be more displaced cladding post U4 explosion.
After Tsunami, then after U3 explosion , finally after U4 explosion
  • #13,693
Yep. Thanks. You are of course referring to the concrete "cladding" of the switching building, yes?
  • #13,694
I was looking at the sheet steel cladding that's come off that U3 & 4 HV switch building and is laying on the ground around it. The images are not great but I thought there may be more of the wall cladding laying around after the U4 explosion vs before. Difficult to say either way...looking for something more interesting in that bunch of unreleased images now.
  • #13,695
Unit 2 transformer yard - oil level is a little on the low side
  • #13,696
Document 2
https://www.physicsforums.com/showthread.php?p=4071111&posted=1#post4071111 Translation [installment 4: PCV repairs]
Translation [installment 5: surveys inside PCV]
17/34 1/3
17/34 2/3
17/34 3/3
  • #13,697
18/34
19/34 1/2
  • #13,698
19/34 2/2
20/34
  • #13,699
Document 2
https://www.physicsforums.com/showthread.php?p=4073726&posted=1#post4073726 Translation [installment 5: surveys inside PCV]
Translation [installment 6: RPV/PCV integrity assessment]
21/34 1/3
21/34 2/3
21/34 3/3
  • #13,700
22/34
23/34
  • #13,701
24/34
25/34
  • #13,702
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120914/1345_chusuiryo.html On 13 September Tepco said the injection rate problem had been solved, but the injection rate declined again on 14 September (a 10% decline at unit 1 from 09:00 PM on 13 September to 01:00 AM on 14 September, and a decline from 01:00 AM to 07:00 AM at unit 2). In both caes the needed rates were secured. As a countermeasure, Tepco is increasing the injection rates. Tepco suspects foreign bodies are remaining in the pipes.
  • #13,703
Guess it is not easy to put in a strainer just before the pipes enter the reactor when everything is seriously contaminated.
  • #13,704
Document 2
https://www.physicsforums.com/showthread.php?p=4076720&posted=1#post4076720 Translation [installment 6: RPV/PCV integrity assessment]
Translation [installment 7: open competitive biddings]
27/34
28/34
29/34
  • #13,705
30/34
31/34
32/34
  • #13,706
33/34
34/34
  • #13,707
Additional information about the long term research and development effort is included in the presentations from the 7 August "workshop on machinery and equipments toward the decommissioning of Fukushima Daiichi NPP" held in Koriyama city: http://www.meti.go.jp/earthquake/nuclear/20120810_01.html
http://www.meti.go.jp/earthquake/nuclear/pdf/120810/120810_01b.pdf Program
http://www.meti.go.jp/earthquake/nuclear/pdf/120810/120810_01c.pdf Presentation (1) Middle and long term roadmap and research and development
http://www.meti.go.jp/earthquake/nuclear/pdf/120810/120810_01d.pdf Presentation (2) Fukushima Daiichi general situation
http://www.meti.go.jp/earthquake/nuclear/pdf/120810/120810_01e.pdf Presentation (3) Practical use of technical catalogue public appeal results
Session 1:
http://www.meti.go.jp/earthquake/nuclear/pdf/120810/120810_01f.pdf Development of remote decontamination techniques inside buildings
Session 2:
http://www.meti.go.jp/earthquake/nuclear/pdf/120810/120810_01g.pdf Development of PCV leakage points identification techniques
http://www.meti.go.jp/earthquake/nuclear/pdf/120810/120810_01h.pdf Development of PCV repair techniques
http://www.meti.go.jp/earthquake/nuclear/pdf/120810/120810_01j.pdf Development of PCV internal survey techniques
  • #13,709
Interesting paper describing the use of muons to image the core of Fukushima Daiichi Reactor #1:
Cosmic Ray Radiography of the Damaged Cores of the Fukushima Reactors.
Konstantin Borozdin, et al.; Physical Review Letters, September 12, 2012
http://arxiv.org/pdf/1209.2761v1.pdf
The paper describes simulations, and concludes that it is feasible.
Azby
  • #13,710
The simulations they did were about imaging an in-vessel melt. I wonder if/how this would work with the core being dug into the concrete at the bottom of the drywell, as simulations show it probably is.
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
467K
21K
  • · Replies 763 ·
282K
  • · Replies 38 ·
16K
12K
