How Do You Design a Circle Class in Java with Overlapping Circle Detection?
  • Comp Sci
  • Thread starter CAF123
  • Tags
    Java
In summary: The radius and centre variables are public members of the Circle class.-Public instance methods that return the area and circumference of the circleAgain, the radius and centre variables are public members of the Circle class.-A public class method to test whether two circles overlap.This is a public member of the Circle class.-Public class methods to set and retrieve the radius and centre coordinates of the circleYou have two public methods - setRadius and getCentre. These take a single parameter - the radius of the circle.-Public class methods to return the area and circumference of the circleThe area and circumference are public members of the Circle class.-A public class method to
CAF123
88
I need to write a class that represents a circle object and includes the following;
-Private Class variables that store the radius and centre coordinates of the object.
-Constructors to create circle objects with nothing supplied, with just a radius value supplied and with a radius and centre supplied
-Public instance methods that allow the radius and centre coordinates to be set and retrieved(via get/set methods)
Code:
Public class Point {
private double aLoc, bLoc;
private double rLoc;
public Point (double a, double b) {
aLoc = a;
bLoc = b;
//First question: how to define r?
//Define a public instance method to retrieve a,b,r
//for a
public double getX() {
return aLoc;
//similar code for b and r.
//Public instance methods to return circumference and area
public double circumference() {
return (2.0)*(Math.PI)*(rLoc);
public double area() {
return (Math.PI)*(Math.pow(rLoc,2));
//Determine if two circles overlap (intersect)
public static  double separation (Point p1, Point p2) {
double xDelta = p1.getX() - p2.getX();
double yDelta = p1.getY() - p2.getY();
//sum of radii
double addradii = p1.getZ() + p2getZ();
//Compute separation
return Math.sqrt(xDelta*xDelta + yDelta*yDelta);
//do I have to determine if they overlap here, or can I, in the main program, use an if else statement?
//want to prompt user for centre and radius implies use a string
public string toString() {
return String.format (''(%g,%g,%g)'', aLoc, bLoc, rLoc);
Questions: the above is my initial attempt at the class. I think what I have written assumes that r is like a z coordinate (my understanding is that the Point class defines a point in 3d space) - so how else would i define r?
Does the rest of the class look reasonable - anything that I may have missed out?
Many thanks
Edit: I am new to objects and methods, so apologies if what I have written does not make sense.
Code:
aLoc = a;
bLoc = b;
//for a
return aLoc;
//sum of radii
Many thanks
It looks to me like you are heading down the wrong path. You have defined a class for Point, but I don't see a class for Circle, which is what the problem asks for.
In response to your questions - the radius is a number, so you should define it as a private member of the Circle class, of type double. You could define the center of the circle as two private members, also of type double. I would dispense with the Point class and focus on the immediate problem.
Discussed above.
The only constructor I see is for the Point class. You need three Circle constructors: a default constructor (no parameters), a constructor with a radius parameter, and a constructor with radius and center parameters. The latter constructor could be written with three parameters - one for the radius and two more for the x- and y-coordinates of the center.
You don't have these methods. The one you have is for Point, not Circle.
Your area method won't work because rLoc is a member of the Point class, not the Circle class. Also, you need to rethink this name - you don't need the location of the radius, whatever that means, just its value.
This method should return a Boolean value, not a double. It should return true if the circles overlap, and false if they don't. It should take a Circle parameter. The name of the method should be something like overlaps, not separation.
It would be used like this:
Code:
// Initialize circle1 and circle2 - not shown.
result = circle1.overlaps(circle2);
// result will be true if there is overlap of the two circles, and false if not.
Is the Point class just an example of a class? It was used extensively in the notes given and I thought it might be applicable here. Do I have to use the point class at all here?
Things you want to do with points should be in the point class. You don't want to have point-like code distributed around a bunch of related classes because it increases code size and makes the code harder to understand, maintain, debug and modify. The OO style is all about localizing functions and properties (of an object) in one place so that it can be reused by the rest of the program. The identification of objects and how they interact is part of software engineering using the OO approach and factoring is an important attribute of making solutions tractable.
What sort of properties does your circle have? I'd say a radius and a centre identified by a point.
If your circle did not use the point class, would it be harder to change the program in the future if you were to modify it to 3d? What if you had squares, rectangles, rhomubs, circle, ellipse, etc. would it be harder to modify if they all had their own point code?
Thanks, I'll have a go with the changes tomorrow. For now, can you give me any hints on how I should actually start this class?
Sure...
Code:
public class Circle {
As for hints on what to put in the class, try following the very explicit step-by-step instructions you were given:
Ok, here is what I have written for the first part;
Code:
 Public class Circle {
private double aLoc, bLoc, rLoc//the centre of the Circle coords (a,b) and radius r stored as private doubles.
is this ok for the 1st part?
For the second bullet point:
Code:
 public Circle () { //with nothing supplied
//set the internal variables
aLoc = 0;
bLoc = 0;
rLoc = 0;
public Circle (double r) { // with only radius supplied
aLoc = 0;
bLoc = 0;
rLoc = r;
public Circle (double a, double b, double r) { //with centre and radius supplied
aLoc = a;
bLoc = b;
rLoc = r;
Correct for the second bullet?
For the third:
Code:
return aLoc;
public double getY() {
return bLoc;
public double getZ() {
return rLoc;
I am not sure about this one.
For the fourth:
Code:
//Public instance methods to return circumference and area of circle
return (2.0)*(Math.PI)*(r);
return (Math.PI)*(Math.pow(r,2));
Yes?
For the final bullet:
Code:
 public static boolean overlaps(Circle c1, Circle c2) {
//Get the distance between the centres of the two circles
double xDelta = c1.getX() - c2.getX();
double yDelta = c2.getY() - c2.getY();
//Sum radii
double addradii = c1.getZ() + c2.getZ();
I am not sure where to go from here. Possibly use an if statement(if separation > addradii then no overlap, else overlap?)
Many thanks.
Code:
The centre of the circle is a point, so why not use the Point class to define it as such? Also, why call the radius rLoc (the radius is a scalar value, not a location, so this name seems illogical to me) instead of something more descriptive like radius:
Code:
      private double radius; //the radius of the circle
      private Point centre;   //the centre of the circle
Code:
aLoc = 0;
bLoc = 0;
rLoc = 0;
aLoc = 0;
bLoc = 0;
rLoc = r;
aLoc = a;
bLoc = b;
rLoc = r;
Using the origin (0,0) for the centre of the circle by default makes sense, but why use zero as the default radius? I would think that a unit circle (radius = 1) would make a more appropriate default. And again, I would make use of the Point
class for the centre:
Code:
public Circle (Point centre, double radius) { //with centre and radius supplied
      /*If the supplied centre is a null object, use the origin as the centre,
      otherwise use the supplied object*/
      if(centre==null) {
            this.centre=new Point(0,0); // new Point object representing the origin
      } else {
            this.centre=centre;
      this.radius=radius;
For the third:
Code:
return aLoc;
return bLoc;
return rLoc;
Usually you want to make variable and method names as descriptive as possible, without being overwhelmingly long. Naming a method to return the radius of the circle "getZ" is not very descriptive. Try to think of a better name. And again, I would make use of the Point class and have a getCentre method instead of the getX and getY methods. You've also neglected to define set methods for setting/changing the radius and centre.
For the fourth:
Code:
Yes?
Don't forget to add import statements before your class definition so that the compiler can find Math.PI and Math.pow.
Code:
Code:
      if(centre==null) {
      } else {
            this.centre=centre;
      this.radius=radius;
Can I write what you have above as
Code:
centre = (a,b);
radius = r;
I wrote:
Code:
 public Point getcentre() {
return centre;
public double getradius() {
return radius;
I am not familiar with the set methods. They are not in my notes either - how would you write the code for the set part?
Also, to determine if the two circles overlap, I am not sure really how to begin this. I thought an if,else statement would be appropriate somewhere but I am not sure how to start.
Thanks again.
Code:
//Sum radii
Many thanks.
Your overlaps method is returning a double when it should be returning a boolean. Yes, you will need to use an if .. else ... block to determine whether the circles overlap. The logic will have to take into account several possibilities:
  • One circle completely inside the other.
  • One circle partially inside the other.
  • Both circles completely separated.
It would be helpful to draw some pictures of these situations, with centers labelled and radii identified. It would be a good idea to use these as test cases to check whether your code is producing the correct results.
Here is a skeleton of what your overlaps method could look like.
Code:
   if (...)
      // One circle inside the other
      return true;
   else if ( ... )
      // One circle partially inside the other
      return true;
   else
      return 0;
Note that each of the first two clauses needs to check two possibilities. For example, c1 inside c2 or c2 inside c1.
Code:
centre = (a,b);
radius = r;
No. For starters, the method parameters are still named centre and radius, so a, b, and r are not declared anywhere. Secondly, (a,b) is not an object of the class Point, in fact, it even isn't syntactically allowed in Java (the compiler won't know how to interpret (a,b)).
If you are confused about the syntax I used; this.centre=centre, you should know that it is fairly common. Both the class variable for radius, and the method parameter have the same name in my example (radius), so to set the class variable radius equal to the method parameter radius, you need to qualify the class variable by the keyword this.
this.centre tells the compiler that you are referring to the class variable rather than the method parameter of the same name. You could avoid having to use the this keyword by using a different name for the method parameter, but it is usually considered best practise to just keep the same name (other programmers will disagree).
If you are confused about passing a Point object as a parameter instead of two numbers, consider that this is the crux of object-oriented programming. The centre of a circle is a point, so it is advantageous to have a Point class, where objects of the Point class represent specific points, like the centre of a circle. You can then use Point objects in code wherever you are dealing with Points, rather than having to rewrite code each time you want to do something like test if two points are the same, or find the distance between two points.
I wrote:
Code:
return centre;
return radius;
good. :approve: (Although it is usually considered best practise to name methods such that the first letter of each word is capitalized, with the exception of the first word, in order to clearly mark boundaries between words. So best practise would be to name your first method getCentre instead of getcentre, and likewise for your second method)
A set method is used to set/change the value of a class variable to that of a parameter which is passed into the method. So, for example, to set the radius of the circle you could have:
Code:
public void setRadius(double radius) {
      this.radius = radius;
You will need a similar method for the centre of the circle (you will probably want to test to make sure the parameter passed to that method is not null)
When doing the set method for the centre, do you mean that I should use if/else, testing..
Code:
 public void setCentre(Point centre) {
 if centre==null {
this.centre = new Point(0,0);
}else {
this.centre=centre;
I take it this goes before the get methods?
In terms of testing for circle overlap, I have :
If distance between centres is less than smaller radius (say c2) and radius of c2<c1 then c2 in c1.
If distance between centres is less than smaller radius (say c1) and radius of c1<c2 then c1 in c2. (that's for one circle inside the other)
Else if distance between centres of the circles is less than or equal to the sum of the radii then intersect.
Else they are disjoint.
To find the distance should I do something like double separation = Math.abs(c1.getCentre - c2.gtCentre) and double addradii = c1.getRadius + c2.getRadius
Does this all seem reasonable?
Code:
 if centre==null {
}else {
this.centre=centre;
I'm not sure exactly what you are asking here. Before you can call the get methods of an object externally, the object must be instantiated (you must create an instance of the object), so one of the constructor methods will certainly be called before any of the get methods. Each variation of your constructor methods sets centre equal to a specific (non-null) Point object, so there should be no problem returning a sensible value ( a non-null Point object) for the centre of your circle in your getCentre method, unless you have a setCentre method which allows setting centre equal to null (which is why you will want to test for that in your setCentre, the same way I did in the example constructor method I gave you).
Seems overly complicated. Why not just compare the distance between the centres of the circles to the sum of their radii?
How would I compute the distance between the centres ? (I don't think what I had in my previous post is correct).
Does your Point class have a method for finding the distance between two points?
Is this right;
Code:
 if centre==null {
}else {
this.centre = centre;
Sorry, what I meant was should I write in the code for the set method in the program before the get methods? Or is it the case that they are meshed together? (I.e setRadius... getRadius... and then setCentre... getCentre...)
I have a lab session tomorrow so I will try all your suggestions then - thanks a lot.
CAF123 said:
Is this right;
Code:
 if centre==null {
}else {
Looks good, except that you are missing a couple of closing braces } and have an extra opening brace at the end instead.
It doesn't matter which order you define them in. You could even define them before you define your class variables, and the compiler will still sort everything out.
I think this is what I had in my very first post, when I computed xDelta and yDelta etc... but instead of defining the actual points (as i did initially) I have just defined centre now, so I am not sure how to compute the separation using just 'centre'
CAF123 said:
I think this is what I had in my very first post, when I computed xDelta and yDelta etc... but instead of defining the actual points (as i did initially) I have just defined centre now, so I am not sure how to how this.
Can you post the code for the Point class from your earlier examples?
I had
Code:
//sum of radii
where getX got the x coord of one centre and getY got the y coord of the centre
CAF123 said:
I had
Code:
//sum of radii
I meant the version of the Point class that you said was in your notes and used in previous examples. Can you post that code? That's the version you will want to use to define centre in your circle class. Objects of the Point class should be used to represent points. Objects of the Circle class should be used to represent circles.
Ah,ok. So in the Point class I should have variables that represent a point (I.e aLoc = a, bLoc =b etc..) and then use these to compute separation/add radii.
Does this mean I need to add set/get methods for these too?
EDIT: the code in my notes is more or less what I used in my first attempt at the program.
Sort of. I would say that your Point class should have attributes (private class instance variables) for the x- and y-coordinates of the point, a constructor(s) to set these variables when an new Point object is created (instantiated), as well as set & get methods for each variable, and some utility methods for doing stuff with/to points, like testing if two points are equal (override the equals method that all Objects have - if you haven't covered doing that in class yet, just don't worry about it for now) and computing the distance between two points (a static method that takes two Point objects as parameters and returns the distance between them).
Something like:
Code:
import static java.lang.Math.sqrt;
import static java.lang.Math.pow;
public class Point {
	private double xCoord;
	private double yCoord;
	//constructor with no arguments creates the point (0,0)
	public Point() {
		this.xCoord = 0;
		this.yCoord = 0;
	//overload constructor to create a point with given coordinates
	public Point(double xCoord, double yCoord) {
		this.xCoord = xCoord;
		this.yCoord = yCoord;
	public void setX(double xCoord) {
	public void setY(double yCoord) {
		return this.xCoord;
		return this.yCoord;
	/*override the equals method such that two points are equal iff
	both their x- & y-coordinates are identical */
	@Override
	public boolean equals(Object o) {
		Point point;
		if(o instanceof Point) {
			point = (Point)o;
		} else{
			return false;
		if(this.xCoord==point.xCoord && this.yCoord==point.yCoord) {
			return true;
		} else {
			return false;
	//static method to compute the distance between two points a & b
	public static double distanceBetween(Point a, Point b) {
		return sqrt( pow(a.getX() - b.getX(), 2) + pow(a.getY() - b.getY(), 2) );
In your Circle class, you would then use the Point.distanceBetween method to find the distance between the centers of the circles (since they are points)
The reason I suggested that you abandon your attempt with the Point class was that you seemed completely overwhelmed by having to think about two different classes (Point and Circle). You were writing a class for Point and weren't taking care of business with the Circle class; i.e., you weren't writing the various members of the Circle class that this problem asks for.
Related to How Do You Design a Circle Class in Java with Overlapping Circle Detection?
1. What is an object in Java?
An object in Java is an instance of a class that encapsulates data and behaviors. It is used to represent something in the real world and can interact with other objects through methods.
2. How are objects created in Java?
Objects are created using the new keyword followed by a call to a constructor method. The constructor creates and initializes the object with its initial values.
3. What is a method in Java?
A method in Java is a block of code within a class that performs a specific task. It can also return a value or take in parameters as input. Methods are used to manipulate object data and control their behavior.
4. How are methods called in Java?
Methods are called by using the dot notation, where the object name is followed by a dot and then the method name. If the method takes in parameters, they are enclosed in parentheses after the method name.
5. Can objects in Java have multiple methods?
Yes, objects in Java can have multiple methods. In fact, it is common for objects to have multiple methods to perform different tasks and manipulate their data in various ways. This allows for more flexibility and functionality in the code.
