Joint PDFs and Expected Values of 3 Cont Rand Vars
  • Thread starter Thread starter SpiffWilkie
    Joint
SpiffWilkie
You know how sometimes, you take a long time to write a question, and then you submit, but it takes you to a login screen and then you lose everything you wrote?
Anyhow...I would just like to verify some work here.
The problems states that there are 3 mutually independent random variables, X1, X2, X3, each with the pdf f(x) = 2x, 0 < x < 1.
a) What is the joint pdf?
For this, I'm assuming I just need to take the product of the three pdfs, giving me 8x1x2x3?
b) Find the expected value of 5X1X2X3.
Am I to assume that this is equal to 5 * E(X1) * E(X2) * E(X3)? If that is true, I would calculate 5 * (∫2x2dx)3 from 0 to 1?
This gives the result 40/27 ≈ 1.48
c) Find P(X1 < 1/2, X2 < 1/2, X3 < 1/2)
I calculated (∫2xdx)3 from 0 to 1/2, giving me 1/64 or .015625I'm struggling trying to connect examples from class/book/internet with actual problems given, so any help is much appreciated.
Thanks,
Steve
Thanks,
Steve
For (b): do not *assume*. This is something you should know. The short answer is 'yes' in this case---that is, that E(X1 X2 X3) = EX1 * EX2 * EX3----- but not in general. Do you know why?
If you are unsure, the best way is to write out everything in detail. For example, you can certainly say that
E(X_1 X_2 X_3) = \int_0^1 \int_0^1 \int_0^1 x_1 x_2 x_3 f(x_1,x_2,x_3) \, dx_1 \, dx_2 \, dx_3,
and you can go on from there.
RGV
RGV
So, in your equation, then just integrate \int_0^1 2x_3^2 dx_3 substituting that into the integral for x2, and then that result into the integral for x1?
Actually, the explanation helped me out with another problem:
f(x_1) = 2x_1, 0 &lt; x_1 &lt; 1 and f(x_2) = 4x_2^3, 0 &lt; x_2 &lt; 1
so, E(X_1^2X_2^3) = \int_0^1 \int_0^1 x_1^2 x_2^3 f(x_1,x_2) \, dx_1 \, dx_2
= \int_0^1 \frac {4}{7} 2x_1^3 \,dx_1
= \frac {2}{7}
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
