Understanding Josephson Oscillations: Solving for the Second Derivative of Theta
  • Thread starter Thread starter CMJ96
    Oscillations
The discussion focuses on solving for the second derivative of theta in the context of Josephson oscillations. Participants work through differentiating an equation, identifying mistakes related to missing factors in the terms. The importance of applying the product rule correctly when differentiating cosine terms is emphasized. After addressing these errors, the correct form of the second derivative is established, leading to a clearer understanding of the equation. The thread concludes with the user successfully resolving their issues with the equation.
CMJ96
[/B]
Sorry about this, I had to put this into wolfram alpha as for some reason it would not work in latex
Assuming Ec and Ej are not dependant on time, I have differentiated the first term in equation 10 with respect to time, and replaced the relevant terms with equation 9. The second term I have differentiated the fraction containing N's using the expression in the "relevant equations" section . This has resulted in the following expression
$$ \frac{d^2 \theta}{dt^2} = -E_c E_J \left(1-N^2 \right)^{\frac{1}{2}} sin(\theta) - \frac{E_{J}^2 sin(\theta) cos(\theta)}{1-N^2} $$
Can someone help me figure out why I am missing a factor of ##1/(1-N^2) ## in the first term and a factor of ##1+N^2## in the second term? My equation looks similar but I appear to have missed a step
It appears you forgot the derivative of the ##\cos \theta## term when you took the derivative of eq. (10).
I see, would I have to apply the product rule to the second term in order to differentiate the ##cos \theta ## properly?
$$\frac{d^2 \theta}{dt^2}= -E_c E_J (1-N^2)^{\frac{1}{2} } sin \theta - \frac{E_J ^2 sin \theta cos \theta
}{1-N^2} + \frac{E_J N sin \theta } {(1-N^2)^{\frac{1}{2}} }$$
Yes, properly, meaning
\frac{d}{dt} \cos \theta = -\sin \theta \frac{d \theta}{dt}
Ahhhh yes, silly mistake... now I'm getting the correct second term (I just have to use the trig identity to tidy it up) , the only issue is that the first term is slightly wrong, I can't see how I can get the ## (1-N^2)^{\frac{1}{2}} ## as a denominator
$$\frac{d^2 \theta}{dt^2} = -E_c E_J (1-N^2)^{\frac{1}{2}} sin \theta - \frac{E_J E_c N^2 sin \theta}{(1-N^2)^{1/2}} - \frac{-E_J ^2 (1+N^2) sin \theta cos \theta}{1-N^2} $$
Then you seem to have still forgotten a term. When calculating
the ##\frac{d \theta}{dt}## should bring a term in ##E_C##, which eventually will modify the term in ##E_C E_J## in your equation for ##\frac{d^2 \theta}{dt^2}##.
Ah yes, sorry, I forgot to include the 4th term in my reply, I have added it now, the denominator should be ##(1-N^2)^{\frac{1}{2}} ## but for some reason latex won't display it
I fixed it for you.
You now simply have to combine the two ##E_C E_J## terms into one and you'll be done.
DrClaude said:
I fixed it for you.
I've got it now, thank you very much for the assistance!
