Jumping into a earthcenter tunnel
  • Thread starter Thread starter schiz0ai
Jumping into a tunnel that goes through the center of the Earth raises intriguing questions about gravity and human experience. As one approaches the core, gravity increases due to the Earth's density, but it eventually decreases to zero at the center. The discussion suggests that a human would not experience tearing apart due to the relatively small scale of the body compared to the Earth. Instead, one would oscillate around the core until air friction causes them to settle at the center. Ultimately, if the tunnel were perfect, a person could emerge on the other side without significant harm.
schiz0ai
What if you would be able to jump into a hole in the ground that went straight trough the middle of the earth.
And what IF
The tunnel stays intact,
You don't fry to death,
You don't suffocate,
You don't hit the walls,
etc
Would you yoyo? Would you be compressed badly? Would you be torn apart?
im curious :biggrin:
Astronomy news on Phys.org
The strength of gravity increases as you approach the core - it's denser than the mantle and crust right? However there is a stage where the gravity will start decreasing to zero at the center. You can actually work it out using the structure of the interior of the Earth as a guide:
http://www.madsci.org/posts/archives/nov99/943288749.Es.r.html
... some notes.
Humans are quite small on the scale of the Earth so I don't expect the difference in field between your head and your feet to be strong enough to rip you apart.
See also: http://www.wired.com/science/discoveries/multimedia/2008/08/gallery_kola_borehole/
You would simply move up and down past the core until friction from the air in the tunnel caused you to settle at the center of the Earth. No tearing apart or anything like that.
Thanks for the replies, i really appreciate it.
Negating friction, and assuming Earth was a perfect sphere, you would gently pop right out the hole on the other side. Just be sure to get a foothold before you started back down!
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
Today at about 4:30 am I saw the conjunction of Venus and Jupiter, where they were about the width of the full moon, or one half degree apart. Did anyone else see it? Edit: The moon is 2,200 miles in diameter and at a distance of 240,000 miles. Thereby it subtends an angle in radians of 2,200/240,000=.01 (approximately). With pi radians being 180 degrees, one radian is 57.3 degrees, so that .01 radians is about .50 degrees (angle subtended by the moon). (.57 to be more exact, but with...
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
