How Can Kepler's Third Law Be Applied to Multi-Object Systems in Visual Python?
  • Thread starter Thread starter Suiram
    Multiple
Kepler's Third Law can be applied to multi-object systems by considering each planet's effects on the Sun separately or through numerical integration of mutual gravitational forces. For a project simulating the solar system with Earth and Jupiter, one approach is to treat the planets as having negligible mass while calculating their influence on the Sun. A proposed method involves using Kepler's laws to determine trajectories and then allowing the Sun to move based on the center of mass of the system. The discussion highlights the complexity of the three-body problem and suggests using Bayesian methods to analyze observed data. Ultimately, numerical integration is recommended as the standard approach for solving such gravitational interactions.
Suiram
Hi, I am doing a physics project at school, which consists of recreating our solar system (with the sun and only 2 planets, Earth and Jupiter) with Visual Python. Then we want to measure the speed variation of the sun caused by both planets, to determine its period in a graph, which would allow us to find Earth's distance from the sun and Earth's mass. (In resume, I want to find an exoplanet, from a distance, in a binary system) But I just realized that Kepler's third law generalized (P^2 = (4 Pi^2 a^3)/(G(m1+m2)) )is for a binary system...
I was wondering if any of you know about the equation for a system who has more than one object? I'm looking forward to doing it with the whole solar system if possible.
What you're asking for is a solution for a gravitational three-body problem - a problem notorious for its complexity. Fortunately, you can consider the planets masses negligible when applying Kepler's law.
Well there are two ways to approach it.
1) consider each planet separately and calculate its effects on the Sun as if it were the only planet.
2) calculate all of the mutual forces of each object on the others and do a numerical integration.
#1 can be done using Kepler's laws and solving Kepler's equation. You'll have to sum the results somehow.
#2 isn't terribly difficult once you understand how to proceed with a numerical integration, but getting to that point can be tough going.
What we're going to do is make a graph using python, with the speed of the sun due to the interference of both planets, and try to find the individual effects of each since its going to show me 2 superimposed sinusoidal functions. Not really sure about how it's going to work, but I'm pretty sure that the three-body problem is pushing the problem too far. And we can't take both planets separatly, because we're trying to simulate it as if we were the observers and were trying to determine the characteristics with only what we can see from a distance. For the moment, we're going to try it with the Bayes theorem, using 6 factors instead of 3 (observed speed, period and phasing, times 2 because there are two planets). What do you think? Any other ideas?
Suiram said:
Any other ideas?
Numerical integration of the underlying ordinary differential equations. This is the standard approach.
Do it that way
Step 1: assume the sun is fixed and find the trajectories of the planets using Kepler's laws and completely neglecting any interaction between the planets.
Step 2: allow the sun to move now, use the planetary motion found in step 1 and find the motion of the sun by requiring the center of mass of the whole system to remain fixed.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
