B Unusual Exoplanet Discovery Using Star Pulsations: KIC 7917485b
  • B
  • Thread starter Thread starter |Glitch|
    Discovery
KIC 7917485b is a unique exoplanet discovered orbiting a spectral type A star, notable for being identified through the star's pulsations rather than traditional methods. The star exhibits variability due to helium changes in its lower layers, causing periodic dimming and brightening. By analyzing these pulsations, astronomers detected a delay indicating the star's orbital motion influenced by the gravitational pull of the planet. The exoplanet has an orbital period of approximately 840 days and is located at an estimated distance of 2.06 AU from its star. This innovative discovery method highlights the potential for new techniques in exoplanet detection.
|Glitch|
This particular exoplanet I think deserves a special thread because of the method used to make its discovery. This exoplanet is unusual in that it is one of the few exoplanets discovered orbiting a spectral type A star, and because it was the only one discovered using the pulsations of the star's helium layer.
Astronomers find a planet through a never-before-used method
But astronomers came up with a novel idea to use the variability of the star itself as a way to look for exoplanets. The star pulses because of helium changes in its lower layers. It puffs up, cools and dims, shrinks, heats and brightens, and then repeats the process multiple times in a day. In a Kepler light curve, this shows up as a periodic dimming and brightening, like clockwork. But this clock shows a delay. The pulsations appear a little early or late, and by calculating this delay, astronomers can measure that the star is actually moving in a back-and-forth, orbital motion. And this movement is due to the gravitational tug of a nearby planet.
Source: Astronomy Magazine, By Korey Haynes, October 04, 2016
KIC 7917485
M = 1.63
R = 2.16
L = 9.9
Teff = 7,067°K ± 192°K
KIC 7917485b
MJ = 11.8 (+0.8, -0.6)
Orbit = 840 ± 20 days (2.06 ± 0.04 AU est.)
According to Kopparapu, et al. (2014) the "conservative" Habitable Zone for this star is between 2.779 AU and 4.798 AU. The snow/frost line (160°K) for this star is approximately 13.62 AU. Considering such an exoplanet could not have formed any closer, it would have had to migrate inward quite a distance.
Source:
A planet in an 840-d orbit around a Kepler main-sequence A star found from phase modulation of its pulsations - arXiv 1608.02945
Likes Bandersnatch
Astronomy news on Phys.org
So basically pulsar timing, but with stellar oscillations instead of pulsar pulses. Interesting concept, and it requires an amazing long-term stability of the oscillation. The star moves by just 13 light seconds in the 2.5 year orbit of the planet. It corresponds to a radial velocity amplitude of 160 m/s, which should be obvious for all radial velocity searches - if they look at this star.
Not pulsar timing, since: 1) This star will not end up as a pulsar or neutron star when it dies; and 2) Pulsar timing is caused by a completely different method. This exoplanet was discovered using the helium layer phase modulation within the variable star and then converted the time delays into radial velocities using the formula from Murphy & Shibahashi (2015).
Source:
Deriving the orbital properties of pulsators in binary systems through their light arrival time delays - Oxford Journals, MNRAS, Volume 450, Issue 4, Pp. 4475-4485 (arXiv free reprint)
The timing is the common feature.
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
