Kinematics and finding acceleration
A weather rocket is launched with a constant acceleration for 18 seconds before the motor stops, reaching an altitude of 5800 meters after 26 seconds. The key equations for solving the problem involve calculating the height and velocity at the moment the motor stops. The initial attempt at finding acceleration was flawed due to neglecting the rocket's velocity after 18 seconds. To solve for acceleration, it's necessary to express the height and velocity equations while incorporating the effects of gravity after the motor stops. The discussion highlights the challenges faced in applying kinematic equations and the importance of correctly accounting for all variables.
JohnCy
A weather rocket is launched straight upwards. The motor provides a constant acceleration for
18s, then the motor stops. The rocket altitude after 26s after launch is 5800m. What was the rocket's acceleration during the first 18 seconds?
[ tex ]x = x_0 + v_0 t + (1/2) a t^2
[/tex]
[ tex]v = v_0 + a t
[/tex]
This answer doesn't seem right to me. I wasn't confident working it out.
5800=.5(a)(18)^2-(.5)(9.81)(8)^2
162a=5800+313.92
162a=6113.92
a=37.7
You forgot to include the initial velocity of the rocket during the second part of the trip with the motor stopped.
I don't know the velocity at 18 seconds. All the initial values are given, they are all zero. The only intermediate value given is 18 seconds. That's why I'm having a difficult time, I'm not sure how to handle all the unknowns. I'm trying to draw some equations from the three graphs I drew but some of the equations don't make sense. Thank you for your reply.
JohnCy said:
I don't know the velocity at 18 seconds.time
you can use your 2nd relevant equation , where v in that equation after 18 s becomes v_o in your first relevant equation . You will have to leave a as unknown, then solve.
Let the "constant acceleration" while the rocket engine is firing be "a". Then the height when the engine stops firing, from s= (a/2)t^2, is (a/2)(18)^2= 162a meters and its speed is 18a meters per second. After that, we have only the acceleration due to gravity: h= 162a+ 18a(t- 18)- 4.9(t- 18)^2. (Do you see why "t- 18"?) Set t= 26 s, h= 5800 m and solve for a.
Thanks for both your help guys. I've been doing physics for all of three weeks now and it doesn't seem to be getting easier. Sorry for the messy equations. I tried to use latex but apparently it didn't work. Thanks again!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
