Kinematics Belt and Pulley Problem
The discussion revolves around solving a kinematics problem involving two pulleys connected by a belt, focusing on the relationship between angular acceleration, torque, and time. The user initially misapplies the concept of equal angular acceleration for both pulleys, leading to confusion in calculating time and velocity. They later realize the need to differentiate between the pulleys' radii and their respective angular velocities, which are not constant due to the belt's movement. The conversation highlights the importance of using piecewise functions to model acceleration and the necessity to minimize time while considering maximum torque. Ultimately, the user seeks clarity on how to effectively relate torque, angular acceleration, and time to solve the problem accurately.
whitejac
I think I made a mistake somewhere..
T = Jα
T = F*R
A)
I started with T = Jα
Since there is no slip, αm = αL
Thus:
Tm / Jm = TL / JL
Plugging in, we find TL = Tm * JL / Jm = 2560
Now use T = F*R.
Tm = Fm * Rm
Plugging in shows Fm = 2666.67.
Since F has to be equal on both pulleys, we use T = F*R again to solve for RL = 0.96m.
B)
Now that we have those solved we can solve for t.
Θ = Θi + 0.5α*t2
The initial conditions are zero.
Since α must be the same for either, we can solve for just one scenario.
m = RLαL
αm = Tm/Jm
αL = r*Tm / RL*Jm
plugging back into this we get
Θ = 0.5(r*Tm / RL*Jm)*t2
Which when applying the condition Θ=1rad, we get
t as the square root of the reciprocal which shows
t = 0.08sec.
This is where I'm in trouble though. My velocity vs time for this equation will not have a maximum or a finish. I can get a minimum but my equation of motion Θ is a parabola without a finish line. What did I do wrong here because I can't calculate a maximum from that velocity graph.
C)
The same angular acceleration? Why?
Because each pulley has to rotate the same theta or else there would be slip. They also have to accelerate at the same rate or one old be going faster than the other.
This is two pulleys connected by a belt, not sharing an axle, right?
If each pulley rotates through angle theta, what length of belt has gone around each pulley?
Okay, I understand now why each pulley cannot have the same alpha. I got stuck in a way of thinking and then I asked someone who was supposedly good at this to look over it and they said that it looked good. Larger wheel has to have a lower angular velocity, rpm's, than the smaller wheel though the length of belt (RΘ) is the same. How then can I adapt my equations to be good for any theta, especially when ω is not constant, but rather increases and decreases with time? My whole foundation was on equating each of them through alpha.
By equating the belt movements. That relates displacement, velocity and acceleration in exactly the way.
I guess I don't see how to relate the acceleration, which based on the maximum torque is T/J and the velocity in a generalized term.
Relating the diameter of each pulley with the velocity,
ND = ND, where N is the number of rotations. I guess I'm having trouble now seeing how T/J can have the derivative taken and give me a velocity because it's not very generalized.
If the two pulleys have radii r1 and r2, and rotate through angles θ1, θ2, the belt movement is r1θ1=r2θ2. To relate the angular velocities differentiate once, to relate the angular accelerations differentiate a second time.
I guess I understand that but here let me show you how i see it,
I understand that
r1Θ1 = x
r1Θ'1 = x'
r1Θ''1 = x''
but we have T=Jα, where T and J are given and T is the max torque. That leaves α as T/J = 26,666.67 and if I differentiate it, as it's a constant, will equal zero.
Conversely, if i integrate r1Θ1 = x then I'm left with Θ = 1/2αt2 + 0. This can't be the answer either as the velocity vs time relationship should ascend and the descend because it starts and stops at 0, unless it immediately stops the instant it reaches the desired position (which would theoretically 'minimize' the amount of time required). So I understand the general relationship between (angular) placement, velocity, acceleration, but I'm having trouble applying it.
whitejac said:
Θ = 1/2αt2
That equation is only valid for constant acceleration. You have to decide how the acceleration needs to vary with time to satisfy the question.
You're right, I'm left with an even more generalized solution. r1Θ1 = x
The question ask me to minimize the time required to move through an angle theta, but it doesn't give me any relationship with time. It just gives me the size, weight and torque of one pulley and then the weight of another.
If I say r1α1=r1α1 then I could say that α1 = T/J at max torque (and it is assumed that this is the maximum amount of force the pulley can exert, thus minimum time. However, this does not give me a t to manipulate. It just says that r1α1 = (0.1m)(0.0015kg-m^2) / (40N-m) and I have 2 unknowns and 1 expression. I could potentially use the knowledge that r1θ1 = r2θ2 but I don't really see how since the theta is arbitrary.
I'm sorry to sound like a broken record ( and make you sound like one too) but this deriving things is a serious challenge for me.
Right, but you cannot keep it at max torque in the same direction since it has to end stationary. So what can you do instead?
accelerate it as fast as possible and then decelerate it just as fast at the 50% marker.
Exactly
haruspex said:
Exactly
To me, this would result in a piecewise function, where
For 0< θ < θ/2
α = T/J
For θ/2 < θ < θ
α = -T/J
For 0< θ < θ/2
α = T/J
For θ/2 < θ < θ
α = -T/J
Right.
haruspex said:
Right.
Okay, then this does puts be back at the same problem though.
At in the first case, 0 < θ < θ/2
I'm in the original instance of α = t/j but this only shows that r2 = (r * J) / (T *α2)
I find it hard to followyour algebra because you don't clearly distinguish the different radii, moments of inertia and torques.
If the angular acceleration of the load is αL, what torque is being applied? What corresponding torque is the load exerting on the motor pulley? What is the angular acceleration of themotor pulley? What total torque isthe motor therefore generating?
haruspex said:
If the angular acceleration of the load is αL, what torque is being applied? What corresponding torque is the load exerting on the motor pulley? What is the angular acceleration of the motor pulley? What total torque is the motor therefore generating?
In order:
Given:
r = the radius of the motor
Jm = the moment of inertia for the motor
Tm = the torque of the motor
αm = the angular acceleration of the motor, which = Tm / Jm
R = the radius of the pulley
JL = the moment of inertia for the motor
TL = the torque of the motor
αL = the angular acceleration of the motor, which = TL / JL
m = RαL as there is no slip.
Thus
αL = rαm / R = rTm / RJmSolving for the torque... I have this:
Tm = Fm * r
TL = FL *R
Where F is the tension in the belt, and theoretically has to be the same or else the pulley/motor are moving.
So Fm = FL
Thus
TL = Tm *R /r = JLαL
If
then
Tm *R /r = rTm / RJm
and
R2 = r2 / Jm, which is finally solvable.
The angular acceleration of the motor pulley is Tm / r as stated above
The total torque would be... the maximum torque given in the problem? I am not quite sure what you mean by this.
No, that is what it would be if there were no belt attached.
okay, but you said here:
So I'm a bit confused as to where the distinction lies and how to see it in the future.
This is an example of why you need to be clear about what your variables are. I read that post as purely a generic statement that the acceleration should be max in one direction for half the distance and max in the other for the second half. I did not read the T and J as referring to a specific torque and MoI in the context of the problem, since there are more than one of each.
In the equation ΣF=ma, ΣF is the net force. In exactly the same way, we have Στ=Jα, where Στ is the net torque. The driving pulley is subject to two torques, that from the motor and that from the load.
I've been working on this most of the day between work.
Here's what I've come after studying some notes my professor put out and trying do it. This relates the torque with the two pulleys in terms of J and alpha.
His notes have a dynamic expression for belt driven pulleys with a rotating base:
Tm = Jmαm +1/N * JLαL, where N = R/r
And
m = RαL <- this is the expression we've been tossing around.
=> αL = r * αm / R
Then
Tm = Jmαm +r/R * JLr * αm / R
(R2 / r2)(Tm - Jmαm) = JL* αm
R = SQRT[((r2)JL * αm) / (r2)(Tm - Jmαm)]
However, if Tm = Jmαm only applies to a motor without a belt attached, then I am still left with 1 equation and 2 unknowns
You have not used the fact that the time is to be minimised.
How would this look? From what my professor has told me, you set the torque to its max so that your arm/pulley/etc uses the minimum amount of time (though you'd factor in some safety in a real application because it's highly idealized)
Yes, but in this question you are asked to find the R which minimises the time.
Well, in that case I would set R to the minimum it could go. Using the expression
I would... set R to zero? That doesn't make sense.
Why would that minimise the time?
Reduction in R reduces the length, thus the amount of time.
But it also changes the acceleration, so maybe you don't want the minimum length.
  • #31
I'm running out of variables here. The only other one not given is αm, which is something I currently do not know how to find specifically.
  • #32
Concentrate on how the time depends on R. Your equation in post #23 does not include time. You need an equation that relates R to time.
  • #33
I know it doesn't, that's why taking derivatives isn't something I can currently do. I don't know where to put the t because it seems like I'd just be placing it arbitrarily. R isn't related to time as the pulley isn't growing or shrinking with relation to time. The Radius reduces the acceleration linearly, as shown in the relationship but I have not seen from the beginning how I can conjure a t and justify it as a logical relationship.
  • #34
The time taken would be different with a different R, so the two are related.
If the load accelerates from rest at αL, how long will it take to turn through angle θ/2?
  • #35
I simply don't know.
  • #36
It's completely analogous to linear motion. If an object accelerates at constant rate a, how far will it go from rest in time t? Use SUVAT or just integrate.
  • #37
I've never heard of SUVAT, but this is what you mean? Integrating theta twice would yield the second equation regardless.
Okay, a load accelerating from rest at αL would have the position equation:
θL = θ0L0Lt+1/2αLt2
when θLL/2 and I.C.'s are applied:
θL = αLt2
And t = SQRT[θLL]
  • #38
whitejac said:
I've never heard of SUVAT, but this is what you mean? Integrating theta twice would yield the second equation regardless.Okay, a load accelerating from rest at αL would have the position equation:
θL = θ0L0Lt+1/2αLt2
θL = αLt2
And t = SQRT[θLL]
Right. So minimising time means maximising αL, which is not surprising but worth checking.
In your post #23, you eliminated αL and kept αM. But αL is what we need to maximise. So you need to revisit that and obtain the equation that relates αL to τM, r, R, JL and JM.
  • #39
Okay, so I have done most of this but am out of town and away from the computer unail Sunday night.
I have rearranged Tm into an expression that has αL. Considering what you said about Radius R being the thing that changes the angular acceleration here, I took the derivative with respect to R and got an expression. To maximise alpha, I set the derivative equal to 0 and then solve for R. This became a heft fraction I cannot easily type on my phone.
Regardless, once I solve this, I will have the maximum apha and thus the Radius that minimizes the time required to go about a theta?
  • #40
Yes, that should work.
Likes whitejac
  • #41
I've finally figured it out! I have to say, I am embarrassed how much I forgot of my multivariable calculator class. I thought I understood it better than this, but I suppose application is the real challenge.
Thank you so much for your patience. I will post back Sunday night with my attempt at part 2 and 3 but I believe it will not be too much of a challenge. It ought be similar in concept to this. The SUVAT has an expression with t, so I would relate it and the new found expression? Forgive me if this doesn't seem coherent. I'm not near paper to validate myself, but wanted to get the main idea straightened so I could mull it over during my trip.
