Kinematics Involving Ball, What did I do wrong?
  • Thread starter Thread starter dantechiesa
    Ball Kinematics
The discussion revolves around calculating the total time a model rocket spends in the air after its fuel burns out. The rocket accelerates upwards at 3.5g for 4.3 seconds, reaching a velocity of 147.49 m/s and a height of 317.1035 m. The challenge arises in determining the time during the second phase of motion after the rocket's fuel is depleted, where the initial velocity is not zero. A fellow student suggests treating the second phase's initial velocity as zero, which is incorrect; the rocket retains its velocity at burnout. The correct approach requires using the initial velocity from the first phase to calculate the time until the rocket returns to the ground.
dantechiesa
Your cousin has built a model rocket that she wishes to launch in your backyard. You're a little worried by this, and ask her for details.
She tells you, when I launch the rocket straight upwards, the acceleration will be 3.5g = (3.5*9.8m/s^2) for 4.3 seconds, then burn out.
A) What is the max height the rocket will reach
and specifically, what I need help with, what will the time from launch until the rocket returns to the ground.
V^2 = V0^2 +2ad
d = v0t + .5at^2
3. The Attempt at a Solution
So, what I am having trouble with is calculating the time the rocket spends in the air after its acceleration fuel burns out (after 4.3 seconds)
Phase 1: the initial 4.3 seconds
Phase 2: the remaining time it spends in the air
Phase 3: the rocket falls to the ground.
Right when the first phase ends, I was able to calculate its
Vf = 147.49m/s^2 (subsequently is the V0 for phase 2)
d = 317.1035m and phase 2 distance = 1102.5m
However, when I try to calculate time, the quadratic formula isn't giving the correct time.
I input into my calculator
1102.5 = 147.49t - 4.9t^2
0 = -4.9t^2 + 147.49 - 1102.5
This is giving 2 positive roots.
What have I done wrong?
I assume this is the additional distance the object rises.
To solve for the total time after the rocket burns out, consider the initial and final positions for that segment of the motion.
V^2 = V0^2 +2ad
d = v0t + .5at^2
Hmmm. I'm a fellow student wanting to help out!
What i did was treat the second phase's initial y velocity as 0 because the rocket "burns out" which means its velocity is 0. With the distance being 317.1035 and initial velocity being 0 and the acceleration is positive 9.8 m/s^2, i calculated t=8.04 secs for the second phase. time for phase1 + phase 2 = 12.35 seconds.
I'm am not entirely sure if that's right though!
Not quite so. At burnout the rocket has the altitude and velocity attained to that point. So the post-burn motion starts with a nonzero position and a nonzero velocity.
