Solving Kinematics Problem: Who Wins the Race?
In summary, Alvin races Ophelia to Physics class. Alvin has a headstar of 13m and travels at a constant speed of 7m/s. Phelia is initially traveling at 1.2m/s but then begins to accelerate at 1.5m/s2 until she reaches the physics classroom 100m away from her. Phelia catches up to Alvin at 9.5486 s.
undefinable
Who wins the race? when and where did ophelia catch up? (both metres and time)
d=vit+1/2(a)(t)2+di
Who wins the race? I was able to figure out that alvin completed the race at 12.4s and phelia competed the race at 10.8s (though I'm not sure if its right)
I got stuck trying to find out WHEN they caught up. I tried setting the equation to
vit+1/2(a)(t)2+di=vit+1/2(a)(t)2+di
and plucking in the numbers for both sides but when I tried to find the variable for time, I put it into the quadratics formula. I ended up have no real roots (square rooting negatives)
Basically you want to find the time when Phelia's displacement equals Alvin's displacement plus 13 meters. Or [itex]\triangle D_P = \triangle D_A + 13[/itex]
If you know where they crossed, plug that x value into Alvin's EOM to get t.
Start by listing the information you have:
df = 100 m
Alvin
di = 13 m
v(t) = vi = 7 m/s
a = 0
==> d(t) = di + vit = 13 + 7t
Ophelia
di = 0 m
v(t) = vi = 1.2 m/s
a = 1.5 m/s2
==> d(t) = vit + (1/2)at2 = 1.2t + 0.75t2
It seems that your approach for answering the first question is correct: find out how long it takes for each person to run 100 m:
Alvin:
100 = 13 + 7t
t = (87 m) / (7 m/s) = 12.43 s
Ophelia:
100 = 1.2t + 0.75t2 =
(3/4)t2 + (6/5)t - 100 = 0
using the quadratic formula, t = 10.77 s
It looks like you're doing alright so far.
Now, to find the the position and time at which Ophelia catches up, you equate the two trajectories (since their positions are equal at this instant)
13 + 7t = (3/4)t2 + (6/5)t
0.75t2 - 5.8t - 13 = 0
Solve for t using the quadratic formula with
a = 3/4
b = -5.8 = -29/5
c = -13
t = 9.5486 s
Alvin:
d(t) = d(9.55) = 13 + 7(9.55) = 79.8402 m
equivalently
Ophelia
d(9.55) = 1.2(9.55) + 0.75(9.55)2 = 79.8402 m
Since your methods are right, I went over the full solution. You must have just made a mistake in setting up the final quadratic equation
What is kinematics?
Kinematics is the branch of physics that studies the motion of objects without considering the causes of their motion.
What is a race in kinematics?
A race in kinematics is a problem that involves multiple objects moving in a specified path to determine which object reaches a certain point first.
What are the key concepts in solving kinematics problems?
The key concepts in solving kinematics problems are displacement, velocity, acceleration, and time. These concepts are used to calculate and analyze the motion of objects.
What are the steps to solve a kinematics problem?
The steps to solve a kinematics problem are:
  1. Identify the given information and what needs to be solved
  2. Choose the appropriate kinematics equations
  3. Substitute the known values into the equations
  4. Solve for the unknown variable
  5. Check for units and significant figures
Can kinematics problems be solved graphically?
Yes, kinematics problems can be solved graphically by plotting the given information on a graph and analyzing the slope and shape of the graph to determine the motion of the objects.
