Kinetic Energies of Particles in Nuclear Decay
The discussion centers on a homework problem regarding the kinetic energies of particles resulting from the alpha decay of a stationary uranium-238 nucleus. The main question is to determine the ratio of the kinetic energy of the daughter nucleus to that of the alpha particle. Participants suggest using conservation of energy principles and the kinetic energy formula (1/2 mv^2) to approach the problem. A proposed method involves calculating the rest masses of the uranium-238 nucleus, the daughter nucleus, and the alpha particle to find the energy converted to kinetic energy. Clarification is sought on whether the focus should be on kinetic energy ratios or other aspects of the decay process.
lifeiseasy
A stationary uranium-238 nucleus undergoes alpha-decay. What is the ratio of the daughter nucleus to that of the alpha-particle?
P.S. It's a practice problem for which I had the final answer, but I'm not sure how to reach it.
I guess it's based on conservation of energy. I'm unsure of the equations, though.
1/2 mv^2 for K.E.
Sorry, I just don't know how to start.
the question isn't really clear. Are you trying to find the ratio of kinetic energy of the daughter nucleus to the alpha particle? I am not exactly sure if this is right or what level you are studying at but my approach would be
firstly work out the rest mass of the U238, next you find the daughter nucleus and work out its rest mass, followed by rest mass of the alpha particle, the difference should be what has been converted to KE
