Kinetic Energy and Rolling motion
The discussion focuses on calculating the kinetic energy of rolling objects, specifically a 500g can and a 600g solid cylinder. The correct formula for kinetic energy (K.E.) of a rolling object is K = 1/2*I*(v/r)^2 + 1/2*Mv^2, where I is the moment of inertia. For a hollow can, the moment of inertia is I = (1/2)(M(R1^2 + R2^2)), while for a solid cylinder, I = (1/2)MR^2. The participants clarify that the total kinetic energy includes both translational and rotational components, leading to the correct answers of 0.5 J for the can and 1.35 J for the cylinder.
  • Understanding of kinetic energy formulas for rolling objects
  • Familiarity with moment of inertia concepts
  • Knowledge of solid and hollow cylinder properties
  • Basic physics principles regarding translational and rotational motion
  • Study the derivation of kinetic energy formulas for rolling objects
  • Learn about the moment of inertia for various shapes, including hollow cylinders
  • Explore the differences between translational and rotational kinetic energy
  • Review examples from Halliday & Resnick's "Fundamentals of Physics" for practical applications
Students and educators in physics, mechanical engineers, and anyone interested in understanding the principles of kinetic energy and rolling motion.
Nitrag
A 500g, 8.0-cm-diameter can rolls across the floor at 1.0 m/s. What's the can's kinetic energy.
I solved this using:
Code:
K = [tex]\frac{1}{2}[/tex]*I*([tex]\frac{v}{r}[/tex])[tex]^{2}[/tex]
and for some reason I get 1/3 the answer. So I multiplied it by 3 at the end. Is there something wrong with the formula I'm using?
If i do the same thing with a similar problem I don't get the right answer. I think the difference lies in the 1.50 m/s.
Similar problem:
Code:
A 600 g, 6.50-cm-diameter solid cylinder rolls across the floor at 1.50 m/s.
Can you show the formula u used for I(in terms of r) ?
Oops sry,
I = (.5*m*r^2)
This is the value of I about COM, the cylinder is not rolling about the COM.
Since the can is hollow, you must know the inner and outer diameter of the can to find the MI.
If the walls of the can are very small, the moment of inertia = MR^2
Hey karnataki, specify the axis (coz here I is 3/2MR^2)
Moment of inertia of a hollow cylinder about the axis parallel to the axis of cylinder is = M(R1^2 + R2^2)/2
If the can is thin, in that case R1 is nearly equal to R2.
and MI = MR^2. You have taken the axis tangential to the cylinder and parallel to the axis of the cylinder.
Thats the axis along which pure rotation is taking place, I suppose.
K.E. of rolling can = 1/2*I(com)(v/r)^2 + 1/2*Mv(com)^2
= 1/2*Mr^2(v/r)^2 + 1/2*Mv(com)^2
= 1/2*Mv^2 +1/2*Mv^2
= Mv^2
In such problems radius of the object is not needed.
Hey I(com) = 1/2Mr^2.
Just mv^2 does not work.My buddy has a different values and he got 0.443 for the question:
Code:
I (com) = 1/2(MR^2) is true for solid cylinder.
Total KE of rolling body = KE of translation + KE of rotaion
If possible go through Halliday & Resnic Book of Physics
Oh ya, I'm sorry for the confusion.
So, K = Mv^2 = 0.5 * (1)^2 = 0.5 J
and for the other ques. K = 0.6 * (1.5)^2 = 1.35 J
Are your numerical values same, Nitrag?
Yes, I got 1.35 J also but it is not correct.
For the other question K = 1/2*1/2*(MR^2)(V/R)^2 + 1/2*MV^2
= 1/4MV^2 + 1/2MV^2 =3/4MV^2 = 1.0125 J
ah, I see the connection now. thanks for the help!
  • · Replies 21 ·
  • · Replies 42 ·
  • · Replies 32 ·
  • · Replies 19 ·
