What is the maximum speed of a proton if its kinetic energy is 1.28x10^-14 J?
The maximum speed of a proton with a kinetic energy of 1.28x10^-14 J can be calculated using the relationship between electric potential energy and kinetic energy. The equation W = q x V can be employed, where W represents work done, q is the charge of the proton, and V is the change in electric potential. Additionally, converting energy from electron-volts to joules is essential for accurate calculations in particle physics, as the electron-volt is the standard unit of energy in this field.
  • Understanding of kinetic energy equations, specifically KE = 1/2 x m x v^2
  • Familiarity with electric potential and the equation W = q x V
  • Knowledge of energy units, particularly joules and electron-volts
  • Basic concepts of particle physics and proton properties
  • Learn about the conversion between electron-volts and joules
  • Study the implications of electric potential on particle acceleration
  • Explore advanced kinetic energy calculations in particle physics
  • Investigate the properties of protons, including mass and charge
Students and professionals in physics, particularly those focusing on particle physics and energy calculations, as well as educators teaching concepts related to kinetic energy and electric potential.
lilymay992
Hi! So for my a levels I’ve been doing practice papers and I’m stuck. I have to calculate the kinetic energy of a proton after acceleration except I’m only given the charge of +1.6x10^-19 , a potential difference of 80kV, and a mass of 1.7x10^-27kg
Kinetic energy = 1/2 x mass x velocity^2
So first I tried to use KE=1/2 x m x v^2 but then realized I didn’t have the velocity and I can’t figure out a way to obtain it. I then tried to work out the energy using a different equation, W= q x v but that left me with 1.28x10^-14 J which seemed too small.
I also then have to calculate the maximum speed of the proton which I’m confused at how to do if I don’t have the velocity.
Thanks in advance!
You have the charge and you have the change in electric potential. What does this mean for the change in the potential energy of the proton and where does this potential energy go during acceleration?
Oh so do I use V= p.e. / q because the electrical energy has been transferred to kinetic energy during the acceleration?
That does seem like a viable option, yes.
Thank you for your help!
Note that the joule is the SI unit of energy. In particle physics, however, it's more usual to use the electron-volt as the unit of energy. This is the energy gained by an electron ( or other particle with the same charge) accelerated through 1 volt.
Another way to do your problem is to use the immediate answer in terms of electron volts and then look up the conversion to joules.
  • · Replies 54 ·
11K
  • · Replies 21 ·
  • · Replies 20 ·
