Kinetic Energy of Pulley System with Unequal Weights
The discussion revolves around a pulley system involving two unequal weights, specifically 6 kg and 4 kg, and the calculation of kinetic energy after 4 seconds of movement. The problem is situated within the context of classical mechanics, focusing on concepts such as acceleration, velocity, and kinetic energy.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to calculate acceleration and velocity using different methods, expressing confusion over the discrepancies in results. Some participants question the derivation of the equations used and suggest using kinematics to find speed after a specified time. Others inquire about the methods employed to arrive at the acceleration values.
The discussion is active, with participants providing guidance on how to approach the problem. There is a focus on deriving equations from fundamental principles and applying kinematic equations. Multiple interpretations of the calculations are being explored, particularly regarding the acceleration and its impact on velocity.
Participants note that the original problem was provided without additional context or formulas, leading to reliance on external resources for understanding. There is an acknowledgment of the need to clarify assumptions about initial conditions and the application of physics principles.
sequenced_chaos
Force of gravity = 10
http://img80.imageshack.us/img80/1156/kineticec6.png
Pulley System
Two unequal weights, A = 6KG and B = 4KG
What is the kinetic energy of the movement after 4 seconds?
I think my calculations are so far correct... please point me in the right direction.
KE = 1/2mv^2
Acceleration of the two weights
a = g (A-B)
(A+B)
a = 10 (6-4)
(6+4)
a = 2ms
Force of gravity acting on weights
Weight 'A' (6KG)
F = MA
F = 6 * 10
Weight 'B' (4KG)
F = MA
F = 4 * 10
Ive also made an attempt to calculate velocity:
Velocity of masses
V = Sqr 2gh (6-4)
(6+4)
= (Sqr Rt)100
= 10However I made another calculation and found the acceleration of the both weights to be 7.3, and by using SUVAT that the velocity is 29.3 with that figure of 7.3 for acceleration. To be honest I am completely lost, please help.
You found the acceleration. Assuming it starts from rest, what must be the speed after 4 seconds?
Sounds like you found the acceleration using two methods and got different answers. What was the second method that you used?
As far as the first method goes, did you derive that equation yourself or are you using a formula given in your text?
It's generally better to derive your own equations from basic principles (Newton's 2nd law). But the formula and answer for the acceleration that you gave is correct. Use kinematics to find the speed after 4 seconds.
S 25
U 0
V ?
A 2
T 4
V = U + A * T
V = 0 + 2 * 4
V = 8
So where do I go from here? I now know the Velocity, what about the masses.
You have the velocity, now calculate the kinetic energy.
Kinetic Energy = 1/2 M V^2
1/2 10 * 8^2
= 320
So 320 is the final answer?
Yes. Be sure to attach proper units to your answer.
Thanks very much for your time, much aprechiated :D
  • · Replies 22 ·
  • · Replies 22 ·
  • · Replies 58 ·
