Types of Kinetic Energy: Vibrational, Translational & Rotational
There are three main types of kinetic energy: vibrational, translational, and rotational. Random kinetic energy, often associated with heat, is not explicitly defined in undergraduate physics but can be understood as the energy present in particles even at rest. It is suggested that random kinetic energy can be considered a combination of vibrational, translational, and rotational energies. The discussion also highlights that in gases, random kinetic energy predominates unless they are in specific conditions, like within a musical instrument. Understanding these concepts allows for a clearer definition of kinetic energy types.
csharsha
I was wondering about the types of kinetic energies that exist. Is it true that there are 3 types - vibrational, translational and rotational?
If so what is random kinetic energy?
Is random KE = vibrational + translational + rotational ?
Thanks !
At first there is only normal kinetic energy of a single particle.
If you prefer you can work with center of mass of objects. Then you'd substitute the above with (center of mass translational energy)+(rotational energy about center of mass)
You can treat everything having these two types of energies only.
From here you can start defining whatever you like. It's just a matter of defining words.
Random kinetic energy is what people relate to heat. I'm not sure what a well-posed definition would be, but you surely can't find it in undergrad physics book, because there it's only vague concepts. Hmm, seems like a good question.
welcome to pf!
hi csharsha! welcome to pf! :smile:
i think i'd say that vibrational means regular …
so if you hit a bell it'll have vibrational KE, but even when it's "resting", there'll still be a tiny amount of random KE, ie heat
(and gases usually have only random KE, unless they're in a musical instrument)
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
