Kinetic energy: what percentage has been lost?
In an elastic collision between a particle of mass 4u and another of mass 196u, the total kinetic energy remains constant. The initial velocity of the second particle is zero, simplifying the equations for momentum and kinetic energy. By setting the equations equal and eliminating variables, the problem can be reduced to a solvable form. The key question is determining the percentage of kinetic energy lost by the moving particle after the collision. The discussion emphasizes the importance of understanding the relationship between initial and final kinetic energies to find this percentage.
totentanz777
So there's a particle of mass 4u that strikes another particle of mass 196u. The collision is elastic. What percentage of its original kinetic energy has the moving particle lost?
m1v1o + m2v2o = m1vf + m2v2f
K1o + K2o = K1f + K2f
so because its elastic, the kinetic energy total will not change, thus the Kt= Kft.
V2o will be zero, because its not moving. It is possible to set the two equations, one for momentum and the other for Kinetic Energies, equal to each other and cancel out v2f. This helps reduce the problem to
24Vo^2 + VoVf = 25Vf^2
how would having this equation help me find the percentages? Am I on the right track at all?
If the collision is head-on, then yes, the problem can be solved.
What is K1F/K10 ?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
