Kinetic, Potential, and Mechanical Energy
The discussion focuses on calculating the kinetic, potential, and mechanical energies of a 0.420 kg ball thrown vertically upward at an initial speed of 12.1 m/s. Participants suggest using the formulas for kinetic energy (K = 1/2 mv^2) and gravitational potential energy (U = mgh) to solve the problem. The initial potential energy is set to zero, and the energies need to be calculated at the initial position, at 1.75 m above the initial position, and at the maximum height. The conversation highlights the need for clarity on the relevant equations of motion. Overall, the thread emphasizes the importance of understanding kinetic and potential energy calculations in physics.
BreezyHani
A .420kg ball is throw vertically upward at an intial sped o 12.1 m/s. If the initial potential energy is taken as zero find the bal's kinetic, potential, and mecanical energies a.) at its intial position b.) at 1.75m above the initial position, and c.) at its maximum height
I don't know what formula to use guys :( my brain is hurting from organic chem overload.
Expressions for Kinetic energy and Gravitational Potential energy would be a good start.
You may want to use the standard equations of motion, but KE and PE are all you really need.
Kinetc energy I use the: K=1/2mv^2 right? gravitational i use the U=mgy ?
Those formulae will work
ok thank you!
