Kinetic Theory of Gases & Escape Speed
The discussion revolves around calculating the temperatures at which the root mean square (rms) speeds of hydrogen (H2) and oxygen (O2) molecules match Earth's escape speed of 11,200 m/s, yielding results of 10,000 K for H2 and 160,000 K for O2. The main question is whether significant amounts of these gases exist in the upper atmosphere, where temperatures are around 1,000 K. The textbook suggests that there should be little H2 but some O2 present, which raises confusion about the reasoning behind the absence of hydrogen. The contributor argues that since 1,000 K is much lower than the calculated temperatures, both gases should not have enough energy to escape. Additionally, there is a side inquiry about whether 1,000 K occurs when the atmosphere faces the sun.
emperrotta
In the first 2 parts of the problem, I calculated at what temperatures the rms speeds vrms of H2 molecules and O2 molecules would equal the escape speed of Earth (11200 m/s). The answers I calculated for this were 10000 K for H2 and 160000 K for O2. Those answers are correct according to the back of the textbook.
The last part of the question states: Considering the answers to parts (a) and (b), should there be much hydrogen and oxygen high in the Earth's upper atmosphere, where the temperature is about 1000 K?Attempt at a solution
According to the back of the textbook, the answer is no for H2 and yes for O2.
My thought process was the answer is yes for both because the temperature of 1000 K high in the Earth's upper atmosphere is small relative to both the temperatures I calculated (10000 K for hydrogen and 160000 K for oxygen). Thus the temperatures of either gas molecules will not reach a high enough temperature to have a large fraction of the molecules of either gas reach the escape speed of Earth.
How is the answer no for hydrogen? What am I missing here?
I'm not sure how high up in the atmosphere 1000 K would correspond to, but the escape speed taken in respect to that elevation should be less than when taken at the surface of Earth.
Just a side question...the atmosphere would be 1000 K for when it is facing the sun, right (that seems a bit high otherwise)?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
