Understanding Kinetic Theory of Gases: Classical vs. Quantum Approaches"
The kinetic theory of gases primarily relies on classical mechanics, which provides accurate results under conditions of low pressure and high temperature. While classical theory effectively describes molecular collisions, quantum mechanics should theoretically apply due to the uncertainty principle, especially at high temperatures where collisions may become ionizing. Most assumptions in kinetic theory, such as the negligible forces between molecules and elastic collisions, hold true regardless of whether classical or quantum mechanics is used. However, the calculation of mean free path introduces complexity, as it assumes molecules are spheres, which may lead to errors in estimation. Overall, the kinetic theory remains largely valid, bridging classical and quantum perspectives in gas behavior.
manofphysics
In the kinetic theory of Gases , we rely purely on classical mechanics. We derive the equations using classical mechanics, and they turn out to be fairly accurate at ideal gas approximation condition of low pressure and high temperature.
Now my question is, since in the kinetic theory , we are considering the collisions of atoms or molecules, why does classical theory give accurate results? In view of the uncertainity principle ,Ideally, Quantum theory should be applied?
I think quantum effects become appreciable when we go beyond the conditions for which the ideal gas equation gives approximately correct answers,for example when we go to very high temperatures and the collisions become exciting or ionising.
So much of the kinetic theory is nearly true regardess of the differences between classical and quantum mechanics.
For example, the assumption that the spaces between molecules are so much larger than the sizes of the molecules that it's nearly the case that molecules exert no forces on each other except very briefly during collisions, and collisions are elastic, so you can use a statistical description of independent particles traveling in straight lines most of the time, and having a normal distribution of speeds, random amounts of x,y and z components of velocity, their collisions with walls being the underlying cause of pressure on the walls, etc. Most of these assumptions and line of reasoning in the kinetic theory are not dependent on whether you have classical particles or quantum mechanics.
One exception would be the calculation of a mean free path (mean distance between collisions among molecules) with a formula that has been derived with the assumption that molecules are spheres. I don't know the amount of error introduced by treating molecules as classical spheres. It is often assumed for much of the kinetic theory that molecules are geometric points, having zero probability of colliding with one another, and colliding only with the walls, but then this point mass assumption has to be dropped to permit an estimation of the mean free path.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
