Kinetics of metals reacting with acids
The investigation focuses on the kinetics of magnesium reacting with different acids, revealing reaction orders of 2 for hydrochloric acid, 1 for sulfuric acid, and 1.8 for phosphoric acid. It is noted that high concentrations of sodium and magnesium chlorides significantly slow down the reaction, while small amounts of sodium chloride can increase the reaction rate. The user seeks guidance on determining the order of reaction with respect to Cl- ions, referencing a previous finding of a negative order. They used a practical setup to analyze reaction rates by plotting log rate against log concentration of acid to find the order. Additionally, they are looking for advice on applying thermodynamics to discern whether the reaction follows an SN1 or SN2 mechanism.
james111
hey. I am doing an investigation into reactions of acids with Mg. Firstly, iv investigated how order with respect to the acid varies for different acids
i found that the orders for each of the acids are:
Hydrochloric acid: 2
Sulphuric acid: 1
Phosphoric acid: 1.8
in an article, it said that: the effect of added sodium and magnesium chlorides indicated that high concentrations of added salt slow down the reaction considerably. There is other evidence that small concentrations of added sodium chloride increase the rate of reaction, and it is well known that sodium chloride solution alone is highly corrosive to magnesium, far more so than solutions of nitrates or sulphates.
how would i find out the order of the reaction with respect to Cl- ions?? someone said they did it and they got a negative order, which would make comply with what was said above.
for the orders experiment i just used a relatively simple pracitcal setup- using a range of acid concs and noting the time it took for a certain mass of Mg to disappear. Plotting log rate (=log 1/time) vs log conc acid, i determined the order by the gradient of the graph. Unfortunately, i can't think of a similar way to determine how the order of Cl- ions or SO42- ions using a similar method. thanks for any help
(apparently, i was told that by applying thermodynamics to this problem, i would be able to find out whether the reaction is SN1 or SN2...but i can't figure that one out either. any suggestions please?)
i no that iv written quite a bit and would appreciate any help.
thanks.:smile:
anyone??
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
