What properties does Baym use to derive the L commutation relation?
univox360
In Baym's Lectures on Quantum Mechanics he derives the following formula
[n.L,L]=ih L x n
(Where n is a unit vector)
I follow everything until this line:
ih(r x (p x n)) + ih((r x n) x p) = ih (r x p) x n
I can't seem to get this to work out. What properties is he using here?
Can you show
0 = n x (r x p) + r x (p x n) + p x (n x r) ?
What you want would follow from this.
I understand, but is this identity valid since r and p do not commute? This identity is constructed using B(AC)-C(AB) which seems to change order of operation...
Try using
\left( A \times B \right)_i = \epsilon_{ijk} A_j B_k
and
\epsilon_{ijk}\epsilon_{iab} = \delta_{ja}\delta_{kb} - \delta_{jb}\delta_{ka}
in the three terms in your expression (repeated indices are summed over). Also, n is a triple of numbers, and so commutes with r and p.
I have now done the calculation. The identity can be verified by using
George Jones said:
Try using
and
Yes, using that theorem this works. Thanks so much!
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
